Onkyo Subwoofer SKW-538 makes a pulsing sound. Almost like something is swiching on and off.
5 Suggested Answers
SOURCE: Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Posted on Nov 19, 2007
SOURCE: I have an Onkyo SKW-50 subwoofer and when I turn
may be u have a power problem check if ur ground is well connected to ur amplifer and also check the input cables if there ground wires r intact and make good contact
Posted on Dec 20, 2009
SOURCE: onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Posted on Feb 12, 2010
dunnbiker
  • 8546 Answers
SOURCE: how do i connect my
Read the manuals...
http://filedepot.onkyousa.com/Files/own_manuals/tx_sv515pro.pdf
http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=SKW204_En.pdf
Posted on Jan 22, 2011
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
Apr 27, 2016 | Onkyo Audio Players & Recorders
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
Onkyo skw 150 powered subwoofer output code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
My onkyo subwoofer does not turn on the green ligth is not on, what could it be? is a swk-200
My Onkyo S/W did the same thing untill I unplugged it from the surge protector that all the other A/V devices are plugged into. I plugged the sub into it's very own wall recepticle with it's very own new surge protector. Maybe cleaner power is the answer.
I have an Onkyo SKW-50 subwoofer and when I turn on the power to the subwoofer, it is making a low-level humming sound. When I turn the frequency dial up or down, the sound of the hum gets louder or softer...
Dec 20, 2009 | Audio Players & Recorders
Sep 17, 2007 | Onkyo HT-S780 System
Onkyo sks-ht540 subwoofer
Sounds like power problem of some sort ,have you read the instructions properly.some of these will have on/off switches in the wierdest of places
May 25, 2007 | Onkyo SKW-200 Subwoofer
432 people viewed this question
 Grubhead
Grubhead
