Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
The spinner is going round but at an incorrect speed, and the clothes are still coming out wet
    Champion:
  • 245 Answers
Your belt on the dryer is installed incorrectly. rate me if I helped you. Thanks
Posted on Aug 26, 2010
Why my washing machine vibrate when spinning
if it only vibrates when in the spin cycle turn off the machine and cloths distribution re-balance you have to many heavy cloths on one side of basket. Turn it back on and let it continue this should solve your vibration problem
Jul 13, 2015 | LG Washing Machines
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
I have an Electrolux Washing machine, model FWSB6600FS1 and serial XC73403943, 60 HZ, 10 AMPS top loading The spinner in the middle came off when I pulled a clean, wet down comforter out. Can't...
ok thats your fabric softner dispenser....the flat round disk shape peice goes in first push it rite in agitator until it is seated firm..the other two peices go together snap the bowl shape piece over the cup shape piece..and snap the hold thing ontop the agatator...good luck
Sep 07, 2011 | Washing Machines
GE WASHER 123C8381P001001 SPINS MAKING CRAZY CRAZY NOISE LIKE TO HITTING ALL AROUND
You can eliminate such problem by making the proper loading of fabrics to the spinner\dryer. Arrange the wet clothes properly not allowing any open space in the filling.
Nov 25, 2010 | GE Washing Machines
My clothes are still dripping wet after a complete cycle.
If the washing machine is not spinning to its regular speed then it can be the cause of wet clothes.If there is any cloth got stuck in between the inner and outer tub then this will slow the speed and this can cause the problem.Also if the washing machine spin motor,if its faulty then it can be the reason for clothes coming wet.Also check the motor coupler,if its cracked or broken this can be the reason of motor not spinning to its full speed. --------- But if all this ----- the motor,the motor coupler and the inner tub and outer tub blockages checked ok.And there is no problem seen then the other possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.So the clothes come out wet,because some amount of water will always enter the washer due to faulty water inlet valve. --------- This are the possibilities that has to be checked and confirmed for the problem to be solved.To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore Washing Machines
Clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Apr 18, 2009 | Washing Machines
GE front load washer
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
Aug 15, 2008 | GE Energy Star WCVH6260F Front Load Washer
Maytag washer top load
good guess...is the washer balanced? That can make the spin cycle work ineffectively.
Feb 15, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
