Question about Health & Beauty
The cuff inflates (slower than usual) then deflates rapidly. the readings are wrong. pulse count does not register
  • teachertroy Aug 28, 2010
    I have replaced the batteries with no change in unit problem
  • teachertroy Aug 30, 2010
    I replaced the plastic tubes which did not solve the problem. (inside the unit). I am throwing the device away because the pump does not work or it is an electrical failure. Thanks for your help.
  • 11,800 Answers
You haven't provided the exact brand and model of the monitor so the only thing that i can do is an educated guess: the power source of the device (the batteries if it's a portable unit) have aged and are incapable of providing  the energy needed. Because of that the pump is incapable of providing the required pressure and all the readings are messed up. Replace the batteries and make sure their contacts aren't corroded.
Posted on Aug 26, 2010
  • Azrael SRL Aug 28, 2010
    In that case the unit must be defective_ the air pump is faulty. Since repairing it will cost you more than the unit is worth then just throw it away and buy a new one.
    Or you could try to fix it yourself: open the unit (remove the screws and force the clips off) and try to find out why the pump failed - maybe it has a puncture in plastic pipe leading to the cuff air bladder
  • timmullins Dec 29, 2010
    My wife's wasn't pumping at all. I found there were two pins under the cough. One of those was stuck. I just pushed on it to get it back in to place. Works like new now
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
How to calibrate omega 1445 bp monitor
My first question is how do you know it's not accurate? I would tee in a digital manometer (measure in mmHg), wrap the cuff around a glass bottle and let the cuff inflate. When it fully inflates the cuff...look at the readings between the monitor and your manometer. If they are within a few digits of one another, I would leave it alone.
Inaccuracies with patient nibp readings are usually related to improper cuff placement on the patient. There's usually a mark on the cuff to indicate where the cuff should be placed in relation to the brachial artery. I believe this unit utilizes oscillatory technology to determine readings and an improperly placed cuff can create inaccurate readings.
May 23, 2014 | Criticare omega 1445 BP Monitor
I just put new batteries in my Omron HEM-780. Doesn't work. When it finishes deflating it always says E7. What's going on?
Hi library336
The Omron HEM-780 generally has 5 Error Messages:
1]
ERROR MESSAGE: A single (E) Error message indicates movement during the measurement process, resulting in an inconclusive reading or the absence of a Blood Pressure or Pulse reading caused by a weak Arterial Pulse.
SOLUTION: Remove the cuff. Wait 10-15 minutes. Repeat measurement using approximately 40mmHg more pressure than in the previous measurement.
2]
ERROR MESSAGE: A Double (EE) Error message indicates an under-inflated cuff. Remove the cuff. Wait 2-3 minutes.
SOLUTION: Repeat measurement using approximately 40mmHg more pressure than in the previous, under-inflated measurement.
3]
ERROR MESSAGE: An E directly below another E Error message indicates an over-inflated cuff (in excess of 300 mmHg). Remove the cuff.
SOLUTION: Wait 2-3 minutes. Repeat measurement using approximately less pressure than in the previous, over-inflated measurement.
4]
ERROR: A Blank Screen indicates low or depleted batteries.
SOLUTION: Remove and replace all 4 AA Batteries. Do not mix used and new batteries.
5]
ERROR MESSAGE: An (Er) Error Message indicates an abnormal memory function caused by a faulty internal component.
SOLUTION: Call Omron Customer Service, Toll Free, on (in the USA) 1-800-634-4850 (or on the equivalent Toll Free or Freefone Number in your country).
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 15, 2011 | Omron Health & Beauty
I have a blood pressure sphygmomanometer, how do you take a blood pressure reading and what is normal?
Much easier to go to a store, like Walgreens and get an inexpensive ( like 15 dollars) automatic wrist cuff blood pressure monitor, that will give you accurate and quick readings of your heart rate, and blood pressure, systolic and diastolic, automatically.
Apr 03, 2011 | Walgreens Health & Beauty
The cuff is inflating but is taking a long time to deflate and cutting off the circulation. can this be rectified?
hello
Usually in blood pressure apparatus these type of problems are very common. So do not worry.
Actually when you inflate the cuff the pressure goes into the pipe then unscrewing(mercury bp apparatus) or diflating (digital or manual apparatus) the cuff can release the air. There may be two possibilities that why the your equip is not difflating.
1. either there is a blockage in diflating Knob
2 Or in the pipe
The easiest way is to clean the piping by yourself or take it to the nearest medical appliance store, he will clean it for you.
Good day
Mar 01, 2011 | Timex Health & Beauty
More frequently my Omron HEM-780 seems flaky. It would apply pressure and count up to 112-120 then start deflating, then inflating, etc. Then it would count down by units and end up displaying E. It would...
Part of the problem may the the placement of the cuff. Generally, if it's not placed correctly. the cuff will re-inflate trying to find the correct stopping point for inflation. Any movement of your arm could cause this. Also, if you haven't replaced the batteries lately, you should do that. Also check to make sure there are no air leaks in the rubber tubing or the cuff. Check your Owners Manual for the exact placement of the cuff.
Feb 07, 2011 | Omron HEM 780 Automatic Blood Pressure...
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
My bulb deflates after one squeeze.
you may want to check to see if the holes is connected tightly to the cuff on both ends and you need to check the bulb if it has a knob on it because some bulbs have numbers on them which can be set to release air and you want to make sure that it has a proper setting on and if that is not it then you may need a new bulb, i did. i hope this works for you and good luck!
Jan 30, 2009 | Samsung Manual Inflate Blood Pressure...
Health & Beauty Logo
183 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
