Question about Radio Communications
Changing channels / instruction manual required
The children have managed to change channels on their walkie talkies and I cannot remeber how to configure them back.
They are made by motorola, have the Disney.pixar logo on and are based on toy story (I think).
Under battery cover are the following details.
Type: E54AD. SN: 690WCW0FT6. Tnp:IXUE1005A Mdl: ADVENTURE 01/NOV 2002
  • kevjulie May 12, 2008
    No there isn't - it's all programable pal.
    Thanks anyway.
    Kev
  • 138 Answers
There is a channel selector on top of the unit just beside the antennae or the volume adjustment
Posted on May 12, 2008
I need a manual for this
http://www.upzone.com/downloads/summary/7-manual/1254-the-manual-of-walkie-talkie-atomatic-battery-save-walkie-talkie-88006651.html
May 21, 2014 | BellSouth Auto multi-channels 2-way radio...
I cannot get my bellsouth walkie talkie model 2290 to unlock from a channel
The manual says to press and hold the MODE button for 5 seconds turn on or to turn off the LOCK mode. When locked, it prevents you from accidentally changing channels.
Jan 05, 2013 | BellSouth 2290 Walkie Talkie FRS/GMRS...
I've lost the instructions for changing the channel on the our Hello Kitty KT2022 walkie talkie. It would seem simple (obviously someone played around with it and figured it out) but we can't seem...
To change the channel on the Hello Kitty KT2022 Walkie-Talkie:
-Tap the power button. The channel will blink.
-Use up/down arrows.
-Tap the power button again to save the channel selection.
The entire manual can be downloaded from here:
http://www.spectraintl.com/images/stories/pdf/hk/KT2022%20Manual.pdf
Oct 19, 2011 | Spectra Hello Kitty Mini FRS Two Way...
How do I change channels on a uniden walkie talkie
Press the channel-up/down buttons. See the items marked 3 and 4 on the illustration in this manual.
Mar 11, 2011 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
What channel should i set my motorolla walkie talkie to get the best distance? It seem not to wok beyond 1/4 mile on channel 3.
You didn't mention a model number, so I don't know if your radio is an FRS or FRS/GMRS model. GMRS channels have more power output than FRS does, but GMRS also requires a license for operation. Other than that, the frequencies are so close together that there is no distance advantage gained by changing channels. The manufacturer's distance claims on these radios are pure advertising gimmicks - the radios are line-of-sight only, so if there's anything between the transmitter and receiver, the signal will not get through.
Nov 10, 2010 | Motorola Walkie Talkie 2-Way Radio
I took out the rechargeable batteries (replaced with regular AAA)in my Uniden walkie talkies and now one is set for channel 19 and one for channel 6 so they cannot communicate. How do I set the channels...
Press the channel/scan up or down arrow key to change3 the channel on either radio. Need the operating instructions? You can download/print them here:
http://www.banoggle.com/Products/Uniden/manuals/GMR-325-2om.pdf
Bill B
Aug 06, 2010 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Is there a way I can change the channel on my Walkie Talkie manually. I can't get them both on the same channel.
On the Motorolas you have to press the menu button until your current channel flashes. Then press the plus (+) or minus(-) sign to change the channel. 21 is a great channel and you can get distance on it.
May 10, 2010 | Motorola Walkie Talkie 2-Way Radio
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Oct 23, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Radio Communications Logo
503 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
