Question about Casio Parts Cash Register PC Desktop
How can i set a percentage key, i bought the ER-A440 used and im trying to set a percentage key but I have not been successfull, please help, Ihave been trying for hours!!:(
  • Casio Master
  • 1,646 Answers
Hi. What do you mean by 'set' a percentage key. Is there a percentage key on the keyboard already? are you trying to set a rate? If you want to use it for discounting, you just type an amount to discount in REG mode and press %- to remove it. Please describe your use and I'll try to help
Posted on Aug 27, 2010
We just got a Sharp ER-A440 register (used) and need to reprogram it and get the interface cable RS-232C. We are overwhelmed with how to use this, can you help?
Hi. You do not need an RS232 cable to program the machine. It can be programmed via the keyboard.
Firstly, it would pay to have the battery checked. They use an internal rechargeable battery which should be replaced every four years. If it hasn't been changed, it can leak on the circuit board and damage the machine. If the battery is not holding a charge, it will also lose your programming when the power is turned off. This is part of normal dealer servicing but you can't be sure that the previous owner has had it serviced and checked.
You will need to program department names. This is listed under "programming for departments - alphanumeric characters" in the instruction manual.To change the shop name on the receipt, see the section called "Programming various functions - programming of print messages".Once you have given those two a try, I can point you to any other parts of the manual you will need. Just let me know what else you want to set up.
Nov 23, 2011 | Sharp XE-A402 Electronic Cash Register
How to I change the receipt message with a Sharp er-a440?
Turn key to PGM2 mode 1. type 2614 2. press . (decimal point) 3. press X (next to decimal point - on USA model, labelled @/FOR) 4. now type the line number you want to change e.g 4 for fourth line 5. press X (next to decimal point) 6. now type the new message using the alphabet on the front edge of each button. If someone has removed the letters, you can find a layout in the operating manual under "USING CHARACTER KEYS ON THE KEYBOARD" 7. ST (subtotal) 8. TL (cash button)
If anyone needs / looking for a Sharp ER-A440 or ER-A450 manual,
Programming manual: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_and_ER-A450_programming_manual.html
440 Instruction manual: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_instruction_manual.html
440 service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_service_manual.html
Aug 05, 2010 | Casio Parts Cash Register PC Desktop
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Jan 26, 2008 | Casio Parts Cash Register PC Desktop
CD\DVD Writing
be sure to set "check disk contents after burning" or another similar setting before you burn your cd.
Dec 25, 2007 | Microsoft Xbox 360 Console
Casio Parts Cash Register PC Desktop Logo
60 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
