Question about Nintendo Wii Console
Where can I find a diagram showing how to wire a microphone with a mini plug to usb?
    Problem Solver:
  • 15 Answers
Ask EB games shpo the can give u 1
Posted on Aug 27, 2010
Gxl 2200
The easiest way to do it properly would be to use a small mixer, with an adapter cable from the outputs (usually 1/4") to the line-in of the laptop (usually 3.5mm stereo).
Mar 29, 2014 | CAD Microphones GXL2200 Professional...
My computer doesn't see mic when I plug in to the jack
First, did you plug in the microphone when the computer was off or not? If you connected the microphone while the computer was on, it may not have seen the new device to load the drivers. If the computer found the microphone when it was turned on, then the problem could be driver or hardware related.
You need to make sure that the computer is seeing this as the recording device. Click Start and select Control Panel from the right hand column. Click on the Hardware and Sound link. Select the Manage Audio Devices link under Sound. Click on the Recording tab. Is the microphone listed as plugged in? If it isn't, then the microphone isn't making good contact with the jack, has a bad wire or the jack isn't working. If you have another computer, check if the microphone works on it. That will rule out the microphone being faulty. Next go back to the starting Hardware and Sound Control Panel. Look for the link to the Device Manager under Devices. Expand the section for audio inputs and outputs. Check for a red triangle with an x or yellow triangle with an exclamation point. This indicates a problem with the audio drivers. Check with Toshiba for the audio drivers for your computer and the current service pack for Vista. You may need to uninstall the current driver and then reinstall that driver. A final option may be to check if the external audio input was disabled in the BIOS. When you turn on the computer, you should see a screen that tells you how to access the BIOS. (Usually this is F1, Esc, Del or F2). I find pressing the appropriate key repeatedly after turning on the computer doesn't always work. If you get to the Windows splash screen, turn off the computer at the login screen and try again.
If the microphone is plugged in, set it as the default device. You should be able to record with your software.
If the microphone still doesn't work with this computer and does work with another machine, you will probably be better off using a USB microphone or a USB audio adapter (USB to 3.5 mm microphone and speaker jacks). The wiring of the jack is probably faulty and it's not worth the effort to repair.
I hope this helps.
Dec 25, 2013 | Micro Innovations Microphones MM760 Mini...
Does DELL Inspiron 6400 has a inbuilt microphone? If it does how to make it work?
I am sorry to say but, the 6400/E1505 does not have an internal mic. You need External. Sorry. Specs only show a MIC connection. I/O Ports IEEE 1394 4-USB 2.0 (Universal Serial Bus) compliant 4-pin connectors Flash Memory Slot - Secure Digital (SD) and SD/IO compliant 5-in-1 Combo Card connector - reads MS, MS Pro, SD/SDIO, MMC, xD CD type I/II, & IBM Microdrive through ExpressCard adapter Video: 15-pin monitor connector S-Video: 7-pin mini-DIN connector Audio jacks: Stereo headphones/speakers mini-connector (same as line-out), microphone mini-connector
Dec 09, 2010 | Dell Inspiron 6400 Notebook
I cannot get the computer to recognise the Maxtor device. I had it working 18 mths ago and have now just reconnected it. Not sure if I have all things plugged in correctly but can't find a diagram of...
The correct lead should be Y shaped and two of the limbs plug into two USB sockets on the PC, the third lead has a small jack which goes into the OneTouch. It should light up if it is getting power from the USB and there should be an icon showing for it in My Computer.
Aug 17, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
I need a wiring diagram for a Targus PAUMO1
Not worth it!
One wrong wire could burn out multiple USB ports on your computer (or any computer the device is plugged into).
It would be best to get a new or used mouse.
Apr 24, 2010 | Targus Ultra Mini Optical Mouse With...
Wiring problem on Cobra HG-M75 CB Mic
Pin-1-Shield-Ground
2-Yellow-Audio
3-Red-TX
4-Black-RX
notes:The blue & white wire not used.
Jul 03, 2009 | Cobra HG-M75 Microphone
Broken wire to my microphone on my lifechat lx-3000
You cant wire then directly there is a USB D-A chip that controls the headset converting to 1/8" mini plugs may work one for the mic and one stereo plug for the earcups
Mar 30, 2009 | Microsoft LifeChat™ LX-3000 Headset
Wiring diagram for accessory plug needed.
I am looking for the same wiring diagram. The headset Moto sells is a single earpiece with microphone, so how does that end up being a stereo connection Neto? Just curious how, or is there also a full headset with microphone? ( I dont' know, just asking)
Would this be a 4 ring TRS connector? Sleeve = ground, then left, right, and the tip as the microphone??
Jan 18, 2009 | Motorola Talkabout T5420 (14 Channels)...
Where is port to connect USB cable?
I'm sorry you're having trouble with this. I have put together a picture that shows where the mini-USB plug is supposed to be attached to the camera. I hope it helps. This picture actually shows plugging the AV cable into the receptical, but right behind it is the mini-USB port. This is where you connect the USB cable. It looks like you have to lift the flap on the corner to reveal the plugs.
Nov 24, 2007 | Canon PowerShot SD1000 Digital Camera
Nintendo Wii Console Logo
57 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
