Question about Air Tools & Compressors
My air compressor runs good but wont build pressure
    Problem Solver:
  • 5 Answers
If you have no leaks then the valve that discharges from the compressor cylinder(s) is hanging open. It should shut on the back stroke then open when the compressor completes a compression stroke. They are usuall spring loaded, somtimes not. If the compressior has something that looks like a cylinder head the valvle should be located under it.
Posted on Aug 26, 2010
Have a standup 135 psi porter cable air compressor that will not build pressure. Runs good and has no leaks? Any ideas
The most common cause if this is a valve in head that wont close. Those heads get hot and valves stick open and then no pressure can build.
Dec 02, 2017 | Porter Cable Air Tools & Compressors
Craftsman air compressor model 919.16726 wont build pressure and makes a rattling sound
My compressor runs for about 5 min and shuts off.....does any one knows what could be the problem?
thanks
Aug 20, 2012 | Craftsman Air Tools & Compressors
Put new switch on compressor and now wont shut off.
the regulator is failing to do its job. make sure you have it set properly. if you did, you will likely need a new one. also remember to drain the compressor every month to prevent rust from moisture build up in the tank. good luck.
Jun 03, 2010 | Campbell Hausfeld Air Compressor 32 HP...
Husky 202900 when i turn it on motor runs but it but will not bui
when i turn it on motor runs but it will not build up air pressure
Apr 13, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Compressor runs but wont build pressure
You are probably leaking past worn rings and/or through dirty or broken reed valves. You don't mention a make or manufacturer. Contact them for repair parts.
Thanks for your interest in FixYa.com
Feb 23, 2010 | Air Tools & Compressors
Compressor not building pressure and continues to run
Unplug it and listen for air leak. What pressure does the manual tell you it should run to? The safety release could be bleeding air, listen for that, with it off. Make sure it is designed for more than 60 PSI by manufacture.
Jul 20, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Wont build air pressure
Your problem falls into one of two categories the first is the tank is leaking the second is the compressor is leaking. Try this run the compressor for a minute or two and turn it off if to hear a hiss the tapers off slowly your tank is leaking some were check the drain on the bottom of the tank, the pressure relief valve on the top or side of the tank and all other connections between the compressor and tank.
In the event there is no hiss this means the problem is the compressor you may have a bad reed valve or a bad check valve depending on the type of compressor.
hope this helps
Mar 28, 2009 | Hitachi Air Tools & Compressors
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
53 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
