Question about GE RCA 4-Line Speakerphone
I just got an RCA Model 25423/24 for my office. i am trying to figure out how to transfer to an outside number (like a cell phone). Please help.
  • Carl Navarro
    Carl Navarro Aug 27, 2010
    Transfer or forward? Did you check the manual?
How do i transfer a call to another extension?
Unless your phone is connected to a TAW-848 or higher, your extensions are numbered 101-124 maximum, or 21-36. Try going to any phone but the main one and dialing either 101 or 0 and look at the display. You'll figure out your 3-digit extensions. Now just press TRANSFER and dial that 3-digit number. The outside call is put on hold when you press transfer, so there's no need to use the HOLD button.
As an alternative, you can press HOLD, putting the outside line on hold, and dial the 3-digit number into the intercom dial tone and announce the call for line number x. Or, dial the page code 330 and announce to all phones for the person to pick up line x.
Carl
Jun 16, 2011 | Panasonic KX-T7730 Corded Phone
Automatic transfer to a mobile phone number
This question came up before and it works if you have a TA-824 as the system. http://www.fixya.com/support/t3120724-forward_calls_outside_number
The key is that you go to the intercom and dial 9 to get an outside line. If you get a line, you don't have to program 400 to disable the unused lines. After that, you enable outside line transfer, change the time for longer than 10 minutes if you need to, and dial the 7139 phone number # forwarding code.
Hope this helps. If you're using a different system and it doesn't, post back as a comment with your phone system model number.
Carl
Oct 18, 2009 | Panasonic KX-T7730 Corded Phone
Kx-tg5632 how do i forward call to my cell
you need to call your carrier and get a forwarding code and then a cancell code.
good luck
s
Jun 11, 2009 | Panasonic KX-T7630 Corded Phone
Trunk to trunk transfers
The feature has to be allowed in class of service. you must than hit transfer, dial a 9 than the full number. you need to know how to program the phone system to change class of service. ldtsnj.com
Apr 07, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Transferr callers to cell phone
pick up the headset, dial *72 wait for the fast beeps to end, then dial your cell number. After the cell number rings, pick it up, hang up and your calls are forwarded. (You need to have the call forwarding feature from your land line provider). Dial *73 to release. I do this all the time with my system and it works fine...
Jan 27, 2009 | RCA 25202RE3 Corded Phone
Transferring calls
If you have a partner phone system, you can not.
If you have a Partner ACS, release 6 or 7, you can forward an extension to an outside number, but that is it.
Nov 03, 2008 | Lucent PARTNER18 Corded Phone
Forwarding to cell phones or outside lines
Hi Lauri, the calls can be FORWARDED to a cell phone or the call can be CONFERENCED with a cell phone but can only be TRANSFERED to a phone/voicemail in your office. The information for external fordwarding and conferencing is in the iDCS user guide. Let me know if I can help .....Mike
Aug 06, 2008 | Samsung DCS 12 Corded Phone
Transfer the Call
press sp-phone enter *71029, then enter the outside number, then #, you will hear a tone that means call forwarding is activated.
Jul 29, 2008 | Panasonic KX-T7630 Corded Phone
Forwarding a call
Lift handset, dial 3 or 6 ( depending on model) - key outside line access code - key phone number (eg mobile)- key # - hang up
Dec 18, 2007 | Panasonic KX-T7730 Corded Phone
HELP!
I'm sorry to have to say this, but you were told wrong. This phone does not have transfer capability nor has an intercom to call each other.
The model 25403/4 phones have this capability, but yours does not. Sorry.
Nov 28, 2007 | RCA 25202RE3 Corded Phone
GE RCA 4-Line Speakerphone Logo
147 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
