Question about Panasonic DVD-RV31 DVD Player
Put DVD in Panasonic DVD-RV31 player and display says "---- Read" and nothing happens.
  • 734 Answers
Use TDK lens cleaner and see if it can be read.
Posted on Aug 26, 2010
  • gpayne0703 Aug 26, 2010
    I don't hear the motor at all
  • 32 Answers
-make sure the problem occurs also with any other dvd`s.
-try a music cd or MP3. does this work? then your lens is bad. change lens...
-if none of those cd`s runs, listen if you hear a spinning sound of the servo motor.
-does the servo motor tried to make RPM and gets back to low speed? change the servo motor. you have a motor with too much friction....
its an easy job to do. needs only a solder and screw drivers. of course a motor of range between 3.5 volt to 5 volts
Upon inserting a dvd in the player, the player can't fully read the disc until the display reads "HO2".
Hi , Just simple ,
option 1:
Please open case and clean the lense
or
option 2:
use good lense cleaner cd with liquid.
just drop liquid on to cd cleaner ( excatly on brush)
then you run.
it will solve your problems.
Dec 01, 2010 | Panasonic DVD-RV31 DVD Player
Panasonic DVD-RV31 DVD Player plays black & white only (no color)
Hi,make sure your tv channel says av2 and not av2s as this will play in b/w,hope this helps
Jul 10, 2009 | Panasonic DVD-RV31 DVD Player
Dvd player wont read displays H2O panasonic 2001 model
try cleaning the scanner eye with the cleaner disk
Jun 16, 2009 | Panasonic DVD-RV31 DVD Player
Panasonic DVD RV31 does not read DVDs created by Windows Movie Maker
The only thing that has worked for me is to make a copy of the disk after burning it in Movie maker.
Cordell
Jul 06, 2008 | Panasonic DVD-RV31 DVD Player
DVD player will not read any disc
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VER YCAREFULLY NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knacked and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jun 17, 2008 | Panasonic DVD-RV31 DVD Player
Region free code for dvd-rv31
all you need to do is use the DVD Service Disc that you got when you bought your DVD player,, or  go to www.panasonic.com and e-mail them about getting the codes removed so you can play overseas DVD, they sent me a disk for FREE and guess what it worked,,,, it comes with the instructions, here is what it says,,,
INSERT DISK- and confirm "STOP" is displayed...
USING THE REMOTE press "SETUP"
Go to "DISPLAY" menu
Select "ON SCREEN MESSAGES" then press "ENTER" button
Press ">10" found on the bottom right coner
Press "6" button
Press "4" button
Press "3" button
Press "8" button
A PASSWORD WINDOW SHOULD APPEAR
TYPE IN "3192"
PRESS THE "ENTER" BUTTON TWICE
the disk will be read, when finished remove disk
Oct 15, 2007 | Panasonic DVD-RV31 DVD Player
Panasonic DVD-RV31 DVD Player Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
