Hi i have a philips flat screen moniter 17054 power has gone off ext and internal fuses are ok
    Scholar:
  • 115 Answers
The power of the monitor three way you can connect that one in CPU or ups or the main socket.Please first check the monitor power supply. If it is not the prob then you can to check the monitor if you had the warranty for the monitor then give it for the claim. before that check the VGA and Power cable of the monitor.please check it and inform to me
Posted on May 06, 2008
How can I fix black screen on Philips 42" LCD TV?
chances are it is cracked solder joint on internal board,
check link below, press the helpful button
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Jan 24, 2016 | Philips 42PFL7422D 42 in. LCD TV
MY LG TV HAS JUST LOST THE PICTURE AND THE POWER LIGHT HAS GONE OUT.PLUG FUSE IS O.K.
Many electronics devices have fuses inside. Also power supply circuit devices can, of course, fail. If you want to open it to look for a fuse, there is usually a warning on the back about that. . . I have seen a set that went out as you describe, opened it, found a bad fuse. Replaced the fuse and the set has worked for years since.
Oct 20, 2014 | Televison & Video
My Philips 42PFL5604H/12 has no power
Hi Anonymous,
Set Has no power means either the power is not reaching the set or the power supply section has gone bad. Well if you are handy with some tools please check the fuse, try replacing it with the same type if it is found blown. If the set works, enjoy watching. In case fuse blows again or you are unable to do all this, please consult some TV Tech.
Mar 11, 2012 | Philips Televison & Video
Sony klvs32a10e no power led when switch on, total nothing
Hi, please check your power cable and socket, then make sure the plug into the tv is pushed right in, if this is ok there maybe an internal fuse gone inside your tv or a problem with your power supply board.
hope this helps.
Feb 10, 2011 | Sony Televison & Video
I have a 42 inch floor model large screen tv, by magnavox that I purchased 1987. I've been informed that the "Power Board is gone; that it keeps shorting out the fuses. Please, please help me. It was a...
These have pretty complicated power supplies in them. They have the first switch mode power supplies that were used. It is difficult to say the least to find the parts for this set. The best you can probably do is try to find the whole power supply PCB. Try to contact Tri State module or moduslink. These companies rebuild modules and PCB's. Tri State info:800.203.7484 (ext. 203, ext. 210) or http://www.moduslink.com/Aftermarket_Solutions/index.cfm?ref=ARKADASBUL.NET Good luck and thanks.
Nov 01, 2009 | Philips Magnavox 27MS343S 27" TV
When i press av on my remote control i have tv ext and digital options but where has the options for ext2 and 3 etc gone
Dont know your specific model, **** some new tv's will only allow access to av inputs that is connected with cables and a component. Move your cabling from ext 1 to ext 2 or 3 and see if you can access the av ext. If still no access on ext 2/3 the av input board or backup memory could be faulty.
Aug 10, 2009 | Philips 42PF7220A 42 in. Plasma Television
I have a 7322gz gateway laptop.back lts work but nothing displaye
On most notebooks, switching between the internal display and the external display is done by pressing Fn+F4.
Aug 02, 2009 | Gateway 7322GZ Notebook
Philips 47PFL7422 Flat Screen no power
Check the main fuse
If that is ok look for puffed up capacitors on the power supply
Check the 1000ufd @ 35v change them to 1000uf @ 50volts
Good luck
Feb 08, 2009 | Philips 47PFL7422D/37 Television
Hi watching tv and it just switched off
first of all check out the tv power cord wire is it fine or seems like it got cut from some where or do you get any burning small from the wire.if this the case then repair that wire.if the wire is proper then try that wire in another electric outlet.if everything does not works.then is naturaLLY the internal board error.any of the capacitors or the ICs have gone short .the faulty 1 should be checked and replaced.
Nov 30, 2008 | Philips 42PF5421 42 in. LCD Television
Dell moniter
The power supply has most likely gone out. Check for 12v and 5v output and also the solder arround d903 and d907. The site www.lcdrepair.us sells the part as well as a repair kit and has instructions.
May 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
