Question about Dell 1100MP DLP Projector Multimedia Projector
I replaced the lamp in my 1100 MP and now the projector just freezes up after powering up. i place the old lamp back into the projector and works just fine. Is it the lamp or the projector? Thanks
marsrover
  • 682 Answers
SOURCE: Bad Lamp lights even with new bulb.
confirm that it is not made in china-because some chinese lamps is not good in life time.
Posted on Mar 07, 2008
Marrie
  • 563 Answers
SOURCE: REPLACING MY LAMP
Hi Big Dogg
Replace the lamp and reset the lamp timer.
Lamp timer can be reset by holding down the up arrow key and then following the easy on-screen instructions.
Posted on Mar 25, 2008
welcomejee
  • 10594 Answers
SOURCE: lamp failure
Lamp duty cycle is approx 2300 hours and you know how since long this projector is working with you.
Posted on Aug 22, 2008
projdoc
  • 2237 Answers
SOURCE: Projector will come on but lamp will go out
still too warm. it need to cool down more. could also be a ballast issue. if the caps are drying out, a boost of power could overload it and it'll shut down.
Posted on Aug 19, 2009
  • 3 Answers
SOURCE: Cannot remove lamp assembly from Sharp XR-10X projector
Carefully try using a flat head screw driver on the middle plastic piece. make sure it is off...
Or try coming at it from the other side after taking the top of the machine off you can unscrew 3 screws and loosen whatever might be blocking it
Posted on Sep 08, 2009
I replaced the lamp on my Proxima DS2 after I got the message to replace the bulb and it said about 7 hours left. The new lamp worked fine for several sessions and now I get the following message “Change...
first, if you are the changing the Lamp by your self did you respect the instruction below: - Never touch the lamp by your hand, the lamp is sensitive device that can be damadged if touched by your fingers. - Install the Lamp properly, and do not push it by force, slide it softly, because you can make the lamp body inbalanced with the protective case. have a look at this link it can helps you: http://www.fixya.com/support/t7149356-changed_bulb_self_after_year_half
Dec 07, 2010 | ASK Proxima Proxima DS2 and DX2...
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    3M MP7640i Personal Projector lamp wont light
    it's the vents and the passage to the blower.
    Dec 24, 2009 | 3M MP 7640i Multimedia Projector
    Replace bulb in housing for Infocus IN24.. i want instructions how to remove old bulb from housing.
    1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
    Nov 09, 2009 | InFocus Office Equipment & Supplies
    Plus UP-1100 Lamp Hours Rest Procedure needed. The lamp is replaced but no menu option for resetting hours and Google provides no answer.
    To reset the lamp timer on the Plus UP-1100, turn on the projector, press the menu key, navigate to the power menu, go to the lamp timer, then press and hold the "power on" button on the remote control for 20 seconds - you will see the timer reset to 0000.
    Aug 05, 2009 | Office Equipment & Supplies
    When turned on the projector has a pink spot in middle of the screen with old lamp and also with new lamp. 3M model number MP 8630
    you have a fried polarizer on one of the lcd panels due to excessive dust and heat. may need to replace the whole optical engine.
    Jun 04, 2009 | 3M MP 8765 Multimedia Projector
    Dell 2400 MP projector lamp problem
    could be a heat, fan - sensor issue or a power supply issue. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
    Feb 03, 2009 | Dell 2300MP Multimedia Projector
    Xl-2100u
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your Projector from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Oct 19, 2008 | Sony XL-2100U Projector Lamp for...
    DELL 2300 MP NOT TURNING ON
    Have the same problem here. Have two of these units. Took the bulb out of the one that had the Lamp light on, and put it in the other projector. The other projector worked perfectly. I have three bulbs, they all work in the one projector, they all cause Lamp Light in the other one. The manual states nothing about hard resetting the unit. Also note that, the fans do not power up instantly on power on, they come on about 5 seconds after pressing the power button.
    Aug 30, 2007 | Dell 2300MP Replacement Projector Lamp -...
    104 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
