Question about BenQ E900 19 inch LCD Monitor
I recently purchased a GADMEI external TV card. i used a VGA cable to get it run on my monitor. The problem is, i have a DVD player connected and when i turn it on, the screen goes black and says "out of range". Plz Help
  • fathurshaon Sep 07, 2010
    it's my old philips DVD players that plays only movies and music. I used an external VGA cord to connect it with my monitor. Funny it says a 640x480 resolution is needed, but yet not supported by my monitor and i can't even create a 648x480 res. BTW......... i puchased the VGA version of GADMEI. any more luck ?
  • 11,361 Answers
It is saying out of range because the video resolution is too high for the monitor to display. What kind of DVD player you are using and how it it connected to the monitor?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br />
Posted on Aug 26, 2010
    it's my old philips DVD player that plays only DVD's, CD's, and music. I connected it by using an external VGA cord. Funny it says that a 640x480 resolution is needed but yet i cannot get it to run and i even don't know how to create a 640x480 resolution. BTW i purchased the VGA version of GADMEI. Any luck with my problem ?
Screen blank with white dot
Problem with;
1) Video cable:
A) Video cable connection on motherboard side is loose, and/or on back of LCD screen.
B) Video cable is damaged.
2) screen Inverter:
screen Inverter is bad.
3) LCD screen:
LCD screen is bad.
4) Graphics chipset:
Graphics chipset is bad.
Suggest you connect a VGA monitor to the VGA port (Connector) on your laptop.
See if the problem is the graphics chipset, Or video cable, Or display assembly.
You didn't state what manufacturer and Model Number of laptop this is.
All I can do is state generic information.
This is an example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
The VGA connector will be on the side, or back of your laptop.
For the VGA monitor you can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
Laptop OFF, monitor OFF, connect the external VGA monitor to the laptop.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
There are at least 3 display options.
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(For an example HP's usually use the F4 key for a Display Toggle-Over key)
Display shows the same on the external VGA monitor?
You have a bad graphics chipset.
[ Some laptops have been erroneously stated as having a graphics card, when in fact they do not.
The GPU (Graphics Processing Unit) is soldered directly to the motherboard.
This is Integrated Graphics.
http://en.wikipedia.org/wiki/GPU
There is no changeable, replaceable graphics card. Therefore the solution is motherboard replacement ]
IF, the display is good on the external monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
After diagnosing with an external VGA monitor, post back in a Comment.
Also post the manufacturer name, and model number of the laptop.
Regards,
joecoolvette
Apr 22, 2012 | Computers & Internet
How can I connect my Desktop computer to my Hitachi 57F500 TV? I have an emachines desktop, running MS Win 7 connected from Monitor VGA port to DVI port on TV via Dynex DVI-VGA cable, but not getting any...
Hello
VGA and DVI are not compactable. Your TV has no provision to connect it to computer.
DVI-HDTV Input (Input 1)
Use this DVI-HDTV Input for your external devices with DVI-HDTV output such as a Set-Top-Box, high-band DTV decoders, DVD
players and D-VHS with Digital Content Protection
1. Only DTV format such as 1080i, 720p, 480i and 480p are available for DVI-HDTV input.
2. The DVI-HDTV input is NOT compatible when used with a DVD player from a personal computer.
3. When connecting a Set-Top-Box with a copy-protect digital out terminal, a high definition picture can be displayed
on the screen in its digital form
OK.
Mar 23, 2011 | Hitachi 57F500 57" Rear Projection...
How can i use my acer monitor as a tv i lost my manual
The manual won't help you to much in this regard.
This monitor is a standard type that has both a VGA and DVI input.
Normally what you would use with a personal computer.
If you want to use it as a TV monitor you will have some sort of device that outputs to VGA or DVI.
DVI stands for "Digital Visual Interface" and it's preferable over VGA as it should potentially give you a better image.
This means:
A) A computer. You can build your own media TV and watch internet streamed shows like Hulu, Netfix, use as a DVD player, etc. I recommend this route. No more dependance on Cable companies! You just need internet.
B) Find a DVD, and, or Tuner/Cable/Satellite box that has these outputs.
If you want to use Cable or Satellite, contact your provider company and see if they have a box that will output to either VGA or DVI. Might have a hard time finding one of these, or it might cost more then it's worth.
C) Buy a S-Video input to VGA/DVI output. You can buy these for around $40.
Then you should be able to hook it up to just about any device as most modern TV devices will have an S-Video outputs.
Feb 17, 2011 | Acer AL2032WD 20" Flat Panel LCD Monitor
I want to connect my Thinkpad T30 laptop to HDTV
Depends on what connections are on your laptop and tv check them both. If you have a HDMI port on both you can use that. If not most recent TV's have a VGA port which you can use using a standard vga cable if not they will have a DVI or S-Video port and you will need one of those cables which are all availble from any computer shop. But check which one you need first
Feb 22, 2010 | IBM ThinkPad T30 2366 Notebook
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting Laptop to LCD
the following connections available to connect ur computer to an TV:
S-Video output: If you have video card(external u will have this), you require an s-video cable and you connect s-video out of your computer to the s-video int of our TV.
TV-OUT: if you have video card(external u wil have this) you you require an coxial cable and you have to connect TV-out of your computer to TV-IN of our TV(it is place where cable connection goes from your cable operator)
DVI-D: if you have video card(external u will have this) you require an DVI-D cable you haveto connect DVI-D out of your computer(a white 15-pin port which looks like VGA port) ....
VGA: it is the port on your computer which is only used to connect to your computer but not to your TV or LCD(strictly)
Thanking you,
M. Sridhar
Dec 29, 2008 | Gateway GM5442 PC Desktop
Kawasaki pvs1965
u wann put pc on tv use vga cables have tv that ready for it s video out on video cards wont do it
Feb 02, 2008 | kawasaki PVS1965 Portable DVD Player
MPEG4 HDD Player
Connect your HDD Player to your Television (TV) or Monitor using AV Cable; your TV will become a full of AV Entertainment System.It is Capable of Downloading Files from your Computer,HDD Player can be act as your Mobile Hard Disk that Back-up your Important Files .It is Compatible with 2.5" IDE hard disk up to 500GB (not included)
vk1_3.jpg To computer :
Connect your HDD Player to your Computer using the USB2.0 output cable (cable provided); your HDD Player will become your External Hard Disk that will be managed by your computer Window Software ,Back-up your Important Files. But it need additional 2.5" IDE hard disk to work .
To TV or Monitor :
Your TV will become a full of AV Entertainment System after you connect your HDD Player to your Television (TV) or Monitor using AV Cable.Play movies,mp3 and view picture on TV directly,
vk1_2.jpg Specifications:
  • Compatible with 2.5" IDE hard disk up to 500GB (not included)
  • It support NTFS and FAT32 formats
  • AV out to TV directly, VGA out to Monitor
  • When connected to your Computer, Do not connect your Power Supply
  • When connected to TV,it need power supply ( included,and which is compatible with your country)
  • Displays digital photos and movies on a TV, monitor without the use of desktop or laptop
  • Playable programs: MPEG4, Xvid, Divx, DVD,SVCD, VCD, JPEG, MP3,JPEG picture and MP3 song
  • Portable HDD function: USB 2.0 interface, windows management, be convenient for your study work and entertainment
  • Key button and Remote control operation
  • Supports TV type: PAL and NTSC
  • Audio outputs: stereo 2-ch (RCA)
  • Supports OS: Windows 98/98SE/2000/ME/XP
  • Portable design :132 x 80 x 19 mm
  • weight:215g
In the package comes: 2.5'' HDD player,USB cable,AV cables,remote control,manual ,power supply
Jan 29, 2008 | Computers & Internet
Hp hd dvd player for desktop wont play hd dvds
I had this problem. Turned out that I was using a DVI cable to connect my monitor to the video card, but my monitor was not HDCP compliant. Most HD-DVD's require the monitor to be HDCP compliant for digital output (i.e. over DVI or HDMI connections). Alternately, you can connect to your monitor via its analog (VGA) input instead, but you won't get HD output. I was able to do this using a VGA cable along with the VGA-DVI adapter for the video card output.
Cyberlink has a tool you can run to see if your system is capable of HD-DVD output. http://www.cyberlink.com/multi/support/bdhd_support/diagnosis.jsp
When I ran it, it gave me a red flag telling me my monitor was not HDCP compliant
Aug 05, 2007 | Pioneer VSX-D511 Receiver
BenQ E900  19 inch LCD Monitor Logo
206 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
