Question about Motorola Mobility CLIQ Cell Phone
MY SPEAKER PHONE WONT TURN ON. MY "VIBRATE" RINGER MODE WILL NOT WORK. AND MY CAMERA WILL NOT FOCUS. PLEASE HELP!
Nothing comes to my cell phone voice please !
If you mean you cant hear anything while using it, maybe the volume is down.
If the ringer is silent you might be set to 'silent', 'airplane' mode, or 'vibrate'.
Turn volume up.
Go to your menu.
Disable airplane mode if its on.
Disable vibrate mode.
If these don't work then maybe the mini-speaker connector is loose.
If not that then earphone plug may be oxidized.
Squirt it with a bit of Servisol or other oil-free contact cleaner.
Nov 17, 2017 | Cell Phones
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
Nokia 1100 incoming call is not ringtone but vibration is ok
Dear anusv99
You need to changed u r phone ringer, but somtimes it start by some claning, open ur mobile cover & clean the speaker area with the help of tooth brush gently,if it doesnt work change ringer
Regards
Please let me know ur comment
Feb 26, 2009 | Nokia 1100
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
RAZR ringer (speaker) doesn't work
the speaker inside the phone is in mis contact or it is dead .. try changing the new speakers into it ... it will work ...
if u are not gud at servicing then visit the technician........
Feb 11, 2008 | Motorola Mobility RAZR V3
Alltel pantech camera cell phone pn-218
Check user customizable profile. Whether it is set Vibrator mode in General mode. Even by key press mistake it might happens. Check profiles section. if you feel Risky Contact authorised mobile service stations. thank you !
Dec 23, 2007 | Nokia 1100
Motorola Mobility CLIQ Cell Phone Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
