Question about Sport & Outdoor - Others
I have a tigre 44-40 lever action and i need a ejector its acopy of a 92 will a ejector from a 92 work
  • 11,800 Answers
Even if it's an external copy it might not be identical internally, especially the loading mechanism(even if it's the same caliber). Dismantle it and if you have other original 92 parts, compare to the ones in the El Tigre - if they match then it's very likely that the ejector will. Do a dry assembly (no bolts and no springs) to get a general idea of the fitting. If it matches the you can reassemble. Test it using a blank and move the lever gently.
Posted on Aug 26, 2010
Im trying to know what year model is this smith and wesson 5 rds 38 cal double action with serial # 137623
Why not post something helpful, like a model number? Or the actual caliber? .38s&w? .38 spl?
.38 double action?
.38 safety hammerless?
.38 spl hand ejector m&p?
Aug 16, 2017 | Sport & Outdoor - Others
Remmington 700 new total of 12 shots action works and sounds perfect but missfires leaves no mark on the primer
tear down the action clean the parts look for damage on each easpecially the spring and firing pin, and also the ejector to make sure a round is properly seated against the face of the bolt, do the rounds eject properly?, you may need to order a new firing pin and or spring from the manufacturer, Remmington online, some manufacturers will send you free parts such as smith and wesson who desnt even charge shiping
Jan 04, 2015 | Optics
Wont eject round after firing
Probably the ejector itself, or the extractor.
You weren't too specific.
Is the round staying in the chamber?
Coming part way out?
Coming all the way out, just not ejecting out the action?
Coming out, and staying in full contact with bolt face?
Coming out, dropping away from bolt face?
Etc..........
Jul 19, 2014 | Marlin 70510 336 Model 336 Lever 30-30 Win...
Marlin 22 57m has ejection problems
Check the ejector on the inside right of the receiver. If it does not stick out slightly the flat spring underneath it may be broken. Also be aware that you should open the action briskly. Speed of opening has a major impact on ejection.
May 10, 2014 | Optics
Mossberg 500, shell will not eject
did you check the elevator to make sure its not applying the pressure on the cartridge interrupter and cartridge stop? or that one or both aren't damaged and over bent. the ejector slot on the bolt isn't damaged, or the action slide bars.
Dec 28, 2012 | Mossberg 500 AllPurpose Field Shotgun 20...
Fix broken ejector handle
You need to obtain a replacement flash ejector handle first. If you open the router out, you can push the broken ejector handle out with a small flathead screwdriver, it just slides out forward toward the face of the router if you apply a bit of pressure. Then you just slide in the new ejector handle, which is "keyed" on one side. There is also a small metal lever pin that you need to line up with the spring hole when sliding the new ejector handle into place. Once inserted is will snap gently into place and you are done.
<a href="http://www.ciscobuy.com">Sell Used Cisco Equipment</a>
Mar 15, 2012 | Cisco 2801 Router - 2801
2005 ford ranger edge having problems with wipers/fluid ejectors
Sounds like all your problems stem from the wiper motor,the swich is not the likely problem but it is possible.
Nov 01, 2009 | Ford Ranger Cars & Trucks
Sport & Outdoor - Others Logo
32 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
