Question about Refrigerators
The fuse in the circut board has blown and its made into the board, I was trying to find out where I can get a new circut board.
    President:
  • 3,773 Answers
<P>Get your model number and go to</P><P><A rel='nofollow' href="http://www.marcone.com">www.marcone.com</A></P><P>&nbsp;</P><P>If this was helpful please rate me.<BR>Leo Ponder Appliance-Tyler,Texas<BR><A rel='nofollow' href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</A> </P>
Posted on Aug 26, 2010
Naytag model D8300 Automatic dryer runs but does not dry?
Maytag dryer has one of two issues element/element sensor or board fuse blown, you must expose the board and test the circuts to see if you are getting a complete circut
Jun 13, 2012 | Maytag Dryers
The fuse is blown. Where can I get one. Circuit board says 5A 125 volt, but the fuse says 6.25A 250 volt.
Replace the fuse...not what is written on the circut board....Radio Shack or any electrical repair outlet will have fuses.
Feb 11, 2011 | Royal 1280MX Shredder
LG Frig LFC23760ST 3 Door French Refirgeerator just stopped working. There is NO POWER.
You have a blown fuse on the line incoming voltage circut. Remove the main board cover on the back and look for a glass metal ends 20 amp fuse. You can remove the fuse carefully with a soldering iron and solder a new one back in and you will be running again!
Dec 15, 2009 | LG LFC23760ST Side by Side Bottom Freezer...
Used banana plugs for my amplifier, but bare ends of cable were too long, and then my amplifier short circuited. Silly. I would like to know if the IC is toasted or the power supply (or both). Is this...
If you were playing with the speaker out ----off sure the amp IC is blown or the related circute problem as occured
if you smell the shot circute ...tipically a silicon burn smell....then ...there is a problem in side....
remove the cover and physical check for the blown parts using a tourch if you fing any parts or the bord blackning.........
fault may be there\
some times with a small blown fuse replasement ...cure's it .........
Sep 20, 2009 | Audio Players & Recorders
Wont turn on
Deppends where it arc too, short at the case
just pops a fuse . short in side could need
new output trans ,they are screwed
to the heat sink , check output trans , and
all fuses.
Jul 05, 2009 | Kenwood KAC-728S Car Audio Amplifier
The mileage lumination is no longer working
The problem is blown resistors on the instrument panal circut board. the dash needs to be removed and instrument cluster. Resistors are on the circut board. between six and ten..
May 14, 2009 | 2000 Buick Century
Dell w4201c burning fuse...
hello, definitely if your fuses are blown and your not able to circut trace and find the fualty compnents on the pb then repalce it with a working power supply this may help but also keep in mind you may want to check everything out first get your models service manual so you can verify voltages at test points. something is cuasing the fuses to blow so if you do change the power board and you blow the fuses again then you will need to trace the circut and find out where the short is and what panel or part is cuasing it .
hope this helps
Jan 10, 2009 | Dell W4201C 42 in. Plasma HDTV
Blown fuse in set
seems to be a fualty circut board or some of the circut components gone bad. they can replace or repair them at least untill the tv,s go down a bit more in price i would get the estimates then decide. if it was the screen it self cracked or broken then i would tell you to go for a new tv.
Dec 16, 2008 | Philips Magnavox 42MF521D/37 Television
Blown resistor
if you mhave the circut diagram please check it .
Nov 23, 2008 | Electronics - Others
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
