Question about Vacuums
How to thread a singer 9540 sewing machine - Vacuums
SOURCE: With my K6 Industrial Singer
Hello there, loosen your top thread tension,if it looping on top of the material the tension is way too tight, you will also find changing the thread size to smaller thread, the top tension will also reduce,depending on application a good size thread to use is 25 grade,bobbin tension should have just a slight amount of drag as the top thread and bottom work against each other when sewing.
regards
Tony
Posted on Feb 03, 2009
SOURCE: my singer 4166 sewing machine won't pick up the bo...
I had the same problem straight out of the box. I decided to buy a new machine and came across the 4166. It had more than enough functions and seemed to run smoothly. I too have problems with the bobbin not threading so I took it back into the store thinking I was doing something wrong. The saleswoman had the same problem. I was going to exchange it for another but before leaving I wanted to check to see if it worked. Again, same problem so I left without a machine. I spoke to the owner only to be told that 30% Singer machines are lemons and have to be returned for servicing because they don't work from the start. This is a waste of money and time.
The only suggestion I can offer is to either forget about the machine or take it into be serviced.
Posted on Jun 26, 2010
  • 2926 Answers
SOURCE: I have a quantum 5417
http://www.parts.singerco.com/CPpartCharts/5_59999/5430_5417.pdf
This is a breakdown of the assembly and component locations.
Posted on Dec 22, 2010
  • 264 Answers
SOURCE: I need a threading diagram
The upper thread flows from the left to right as it goes through metalstems (posts) with holes, along the top of the machine head, and thendrops down and passes over and under the upper gension disk and thetake up spring.  Then, moves back up to the take up arm (which moves upand down like a goose's neck when turning the handwheel) then startsthe trip down to the needle, going through a couple metal loops (calledthread guides) and lastly through the needle thread guide and throughthe needle eye, as I recall from left to right (?), this part is moreobvious when looking at it.
Heres a link to a manual for that machine. hope this helps
http://parts.singerco.com/IPinstManuals/16-133_CLASS_16.pdf
Posted on Jan 13, 2011
wentlanv
  • 710 Answers
SOURCE: looking for threading diagram for
Hi tusnig,
You can get a manual for your machine at the following website: http://www.mastersewusa.com/info_s533.html
Copy and paste the address into your browser and go.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Jun 22, 2011
How do i fix my tension,bunches up the thread
sounds like a blunt needle,or tension at wrong setting.replace needle first.adrian,,,,
Feb 12, 2015 | Singer 8763 Curvy Computerized Sewing...
My machine flashes C4 when i want to sew
Clean the bobbin case area thoroughly, and probably the feed dogs, too. Start all seams by holding the top and bobbin thread ends together behind the presser foot for the first few stitches. If you have lost your manual, pick up a new one, free, at http://www.singerco.com
Mar 21, 2014 | Singer 7256 Fashion Mate Sewing Machine
Bobbin Not Winding Correctly
The machine seizes suggest thread wrapped around the shaft.
Jan 21, 2014 | Singer 7463 Confidence Sewing Machine 7463
Singer quantum le my sewing machine is frozen and
Check to make sure you do not have a small piece of thread stuck in the raceway area
Aug 12, 2013 | SewShop.com Singer Model Quantum LE...
I received singer sewing machine 2623 machine and I do not have the manual. How can I get it and how do I fill the bobbin
Singer has manuals for most of their sewing machines available at their site. For the 2623, the manual is only available as a bound copy for $15. Go to http://www.singerco.com/accessories/instruction-manuals and enter the model number then click Search.
I believe on this model, you fill the bobbin with it on the metal pin on the top right of the machine. With a metal presser foot in place, bring the thread up and around the guide that pin. Wrap the thread a few times around the bobbin. Set the lever to the bobbin winding position and begin winding. Stop and trim the excess thread from your initial wraps after it is fully caught. Then complete winding the bobbin.
(On other Singer machines, you fill the bobbin in place with the bobbin cover moved halfway open.)
I hope this helps.
Jul 08, 2011 | Singer Vacuums
My singer sewing machine how do I stop thread from breaking
a good sign when sewing is, when your thread keeps breaking, your needle usally has a spot on the tip and cuts your thread. If that doesn't solve it, it your timing in the machine. Also make sure your tension isn't too tight, that will also break your thread.
Kdog
Dec 29, 2010 | Vacuums
Top thread does not pick up bobbin thread, also clicking sound when needle is down under plate, as if it is hitting something. Please help I have a job to do! This machine is new it's a Singer Inspiration...
indicates needle /hook timing is off check/ adjust or take it to a repair shop for adjustment
singer have a very good manual on how to set timing so download a pdf version from the singer site
Nov 05, 2017 | Singer Vacuums
With my K6 Industrial Singer sewing machine the top thread seems to be too tight. The bottom thread is looping too much on the top of the fabric. The timming is ok. I have checked and rechecked that I have...
regards
Tony
Apr 04, 2008 | Singer Vacuums
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
