Question about Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR
What type of gear oil would I use in a bosch 11241evs demolition hammer drill?
  • 1388 Answers
SOURCE: BOSCH 11236VS HELP ME WITH A PROBLEM
I order parts for my Bosch tools at WWW.toolpartsdirect.com. They have the parts lists also so it is easy to find what you need. Don't forget to order some bosch grease for your tool because you will need to carefully wash-out all the old grease with metal bits. Good luck with you repair. Enjoy
Posted on Dec 16, 2008
  • 101 Answers
SOURCE: Broken Forward/Reverse Switch on Bosch Model 1198VSR Hammer Drill
Yes .. should find it here http://www.toolpartsdirect.com/bosch-tool-parts.html
Hope this is Helpful ! Thanks
comax
  • 154 Answers
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Posted on Apr 13, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
  • 142 Answers
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
Posted on Jul 06, 2009
What type of oil or lubricant does bosch 11241evs hammer drill use?
Bosch Oil (part number 1615437511) comes in 50ml volume. This is the correct amount of lubricant for the Bosch 11248EVS Rotary Hammer.
If you are replacing the oil you might consider ordering the 1617000451 Service Pack. You can order the (part number 1615430019) Oil in 1000ml increments and it gives you more bang for your buck and lasts a while.
Jan 31, 2018 | Bosch Drills
Where is the oil filler hole on the bosch 11241evs
There is no oil filler hole - you have to open the gearcase up (#873) to put oil in. If your hammer is leaking and losing oil you should put a service kit in it and fresh oil. Service Pack 1617000430 for Bosch Power Tool eReplacement Parts
As you can see this is an involved process and I would strongly recommend bringing it to a service center to have a qualified tech do this one.
Aug 16, 2014 | Bosch 11241EVS SDS-Max Rotary Hammer
How do i chack bosch 60 lb jackhammer oil leval
Bosch hammer uses grease available in repair kit. Check ebay or parts house. Remove four hex bolts on the mid section of the hammer and pull off the lower end. Most of the grease goes here. There is a side cover to expose the drive gears if you hear gear noise. Depending on use, only needs grease once a year. Good luck.
Jun 30, 2014 | Makita HM1500B 42 Lb. Demolition Hammer
Hammer doesn't work on model 11241evs
a broken ring blocked the impact bolt in front that must beat the chisel. will not move in no direction. machine is dry or leak .or broken gear shaft ?
Feb 08, 2014 | Bosch Drills
Bosch 11241EVS won't hammer
Not all bits for hammer drills are the same as the slots in the sides of the shanks are different between makes . There is a standard between hilti and ramset drill bits but other makers have different ideas Check out the shanks of your drill bits and look for the slot that holds in the bit.
May 26, 2013 | Bosch 11241EVS SDS-Max Rotary Hammer
How to chisel
The Bosch 1199VSR Hammer Drill is capable of drilling or hammer drilling at two different speeds but can not hammer or chisel only. To do that you need a demolition hammer or roto/demo hammer tool.
Jan 28, 2012 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Bosch 11241EVS combo hammer, spins slowly.
have you tried turning the speed dial up and down a few times, sometimes that works. I am not aware of any to bypass the electronic circuits in this tool.
May 23, 2010 | Bosch Drills
Jul 05, 2009 | Bosch Hammering
Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR Logo
939 people viewed this question
Top Bosch Hammering Experts
John Trevino
ken skalski
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
