Question about RCA F36650 36" TV
We have a 36" RCA television (not a flat screen). We probably bought it in 2002 or 2003. When it is turned on, It changes channels every 5 to 10 seconds. It does not seem to be looking for channels and it does not respond to the ENTER button for choices on MENU. Is it worth getting fixed or is there something I can do myself? when it is turned on, it flips channels every 5 or 10 seconds.
  • RCA Master
  • 11,800 Answers
First you need to find out if the problem is in the remote or the tv - just take all the remotes from that room and close the door, if the channels keep flipping then it's in the tv.
In that case the problem is either in the control panel of the tv - the button for the Channel Up is faulty or the processor has aged and has become unstable and malfunctions.
What you can do is to open the case, locate the control board and try to unplug it from the mainboard (or at least the CH up button). If after that it's still doing that then the tv has died, replacing the control processor will cost way more than the tv is worth.
Posted on Aug 26, 2010
2007 35" rca lcd tv L26HD35D has no picture but i
Sounds like it is probably the backlight. Turn the television on and tune to a channel, then try holding a flashlight RIGHT up to the screen and see if you can see a bit of the picture.
Aug 11, 2011 | RCA L26HD35D TV
Keep changing channel without any input
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
Nov 19, 2009 | RCA F36673ET 36" TV
I have an RCA 36 inch tv, the color is messed up, it has a round circle and it will not change channels
If the set wasn't dropped or physically dammaged the chances of it being the picture tube is very small.
The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Oct 23, 2009 | RCA F36650 36" TV
TV WON'T WORK
its an rca this is a known problem. recently on ghost story cuz owners thought house was haunted. no the tvs ir is so sensitive it will power on and change channels on its own if someone enters the room. friend probably new this was happening. there is a fix but must be authorized repair center.
Jun 03, 2009 | RCA F36650 36" TV
I HAVE JUST BOUGHT A RCA 27 INCH TRUE FLAT TV AFTER HAVING IT FOR ABOUT 1 MONTH IT STARTS HAVING A BIG BLACK BOX ON THE SCREEN SO THAT YOU CAN NOT SEE THE PICTURE BUT YOU CAN CHANGE THE CHANNEL AND GET A...
Somehow you have enabled the Closed Captioning mode. Work your way through the menus to turn it off and the problem will be resolved. The channels that come in normally are not transmitting the closed captioning information, thus no CC black box.
Dan
Mar 28, 2009 | RCA TruFlat 27F520T 27" TV
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
TV turns on & off by itself. Channels also change by themselves.
Make sure your remote is totally away from the set.
Make sure the buttons on the set are not sticky
If both of those are ok, it's your E-Prom in the set. RCA's are notorious for this, not a major repair, maybe $75-100. The 8 leg e-rom is only about $6.00
Apr 11, 2008 | RCA F36668 36" TV
RCA F36685 No audio on cable channels
1)Try hard reset = unplug AC cord overnight
2)Further audio circuit work is shop repair by skilled,senior
RCA products technician........................................T.
Sep 03, 2007 | RCA F36685 36" TV
RCA F36650 36" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
