Question about Powerware 9120 UPS System
No Power I have a powerware 9120, it can be turn on if there was batteries, but it could get drained, the batteries were not charging, on charger card i could get dc voltage from bridge rectifier to transformer(08-43000-00) input, is it possible that ihave a burnt tranformer on charger card?
    Problem Solver:
  • 13 Answers
You should measure AC voltage from the output of the transformer to the bridge rectifier, and after the rectifier you should see a DC voltage (you may also read some "ripple" AC voltage on the DC side as well). Check across each battery to see how many volts DC they are receiving (as they will all be in series connection ie one after the other). Batteries are the usual problem with faulty UPS's. You may have a problem battery or multiple problem batteries and they may need replacing.
Posted on May 06, 2008
I got charger failure alarm on display.
Unless new and hardly used - check the internal batteries. They might be worn out and fail to hold a proper charge. This to be able to deliver power when AC mains cuts out.
Jul 04, 2011 | Powerware 9120 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
Feb 08, 2011 | Powerware 9120 UPS System
I ave a powerware 9120 and get a Charger failure alarm
check your batery, may it was leaked, change it with new battery
Jan 17, 2011 | Powerware 9120 UPS System
The UPS dont go to on batteri
Replace the batteries with new one then power the UPS without load for three hours or more so that the batteries can be charged. Then disconnect or switch off power to the UPS and observe if it will till be on using the batteries. If it will be ON then your problem is solved but if it goes off then your UPS is on BYPASS
Apr 09, 2009 | Powerware 9120 UPS System
Powerware 9120
Greetings!
How many years is your ups working? UPS is usually run by a battery, some of them are disposable and needs replacement. If it does not charge anymore it needs replacement of battery.
Thanks.
Nov 06, 2008 | Computers & Internet
Pw9120-6000
1st, the 9120 is a 700, 1000, 1500, 2000, 3000, 5000 or 6000 Va
if it is a 6000 Va that voltage sounds ok, and the ups as no problem, each battery will be around 12,75 Volts, it will be higher and the charging circle ends.
Jun 27, 2008 | Powerware 9120 UPS System
9120 Battery Failure
sounds like inverter is unhappy(causing the input fuse to blow. maybe, just maybe, this Powerware 9120 has given up the ghost? The inverter can short for a variety of reasons. Try to take out the battery completely, and run it as just a power conditioner. If that works, then you have an unhappy inverter in there.
Feb 05, 2008 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
129 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
