Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Trying to replace the ignition switch in a 1998 chev pick up do we have to remove the steering wheel
    President:
  • 2,309 Answers
It its the switch, no, tis lower down on the column, if you want to replace the key cyl, yes
Posted on Aug 26, 2010
2002 chev surburban switch won,t turn
If the ignition switch is jammed, and you cannot free it by moving the steering wheel back and forth while trying the ignition switch, simply replace the ignition switch tumbler and lock assembly with a new one. Before going to the trouble of replacing the entire ignition switch, try squiring a moderate amount of WD-40 or other light penetrating oil into the ignition switch key hole, let it sit overnight, then try again the next morning. Often, that will clear the issue.
Aug 09, 2014 | Cars & Trucks
How to replace turn signal switch
Disconnect battery,Remove ignition cylinder by placing key in cylinder and turning key to run position,you'll see a small hole under side of steering column cover near I use thin straight pick and find ignition cylinder lock pin, push up and remove ignition cylinder,remove tilt wheel lever, if equipped,by turning counter clockwise,then a couple Phillips screws under column cover, take off in two pieces, remove two screws holding turn signal switch, disconnect connectors and reverse procedure to install.
Jun 21, 2014 | 1998 Ford Explorer
Replace wiper switch
wiper and washer switch in steering column you more likely need to remove steering wheel to get to switch two mountings screws on the right side.disable airbags before replacing switch. first turn off radio ignition switch off then disconnect negative battery cable. wait 20 minutes before removing steering wheel and remove steering column.
Sep 12, 2013 | Cars & Trucks
How do I replace the ignition switch. Key in place, will not turn back to the off positiom, stuck in run. 1993 Chev Silvarado
It is held in with a bolt. You need to remove the steering wheel, lock plate, and turn signal switch to gain access. You will need special puller for the steering wheel and a special tool for removing the lock plate.
Jun 02, 2011 | Chevrolet Silverado 2500 Cars & Trucks
To how remove key ignition 1996 chev
You have to remove your steering wheel and the with the assistance of a special tool you remove the plate under the steering wheel. Then you remove the screw that holds the ignition switch it will come out.
Feb 15, 2010 | 1996 Chevrolet C1500
I have a 1998 Chev 2500. The steering column is locked and no matter what I do it will not unlock. I've tried the key jiggling and such. Any idea's?
have you turn the steering wheel a little to take the pressure of the ignition switch while you trying to turn it.
Nov 24, 2009 | 1998 Chevrolet C2500
How do you replace the ignition cylinder on a 1998 grand cherokee
Try these steps...
Step 1 Disconnect the negative battery cable from the terminal on the battery. Remove the upper and lower steering column covers by unscrewing or unclipping them.
Step 2 Remove the steering wheel by lifting off the center cover, disconnecting the horn wire and removing the retaining nut and washer. Make a mark on the steering wheel spline and the wheel itself so you can line it back up precisely. Pull the steering wheel straight back to remove from the shaft.
Step3 Take off windshield wiper and turn signal switches by pulling them off as you did the steering wheel and disconnect the wiring. Slide the spacer sleeve off of the steering column.
Step4 Unscrew the ignition switch mounting screws. Pull out the ignition switch. Disconnect the wiring connector from back of the ignition switch. Simply loosen the tabs and pull it out.
Step5 Insert your key into the ignition. Turn the ignition switch to the locked position. Depress the retaining pin with a small screwdriver and turn the key to the Off position to free the cylinder. Once it is free, turn the key to lock position and remove the key and key cylinder.
Step 6 Install your old key cylinder into the new ignition switch assembly. Make sure the contacts in the cylinder and assembly line up. Reattach wiring to ignition switch, slide it into place, screw in mounting screws and reassemble steering wheel and switches.
Thanks
Smith
Jul 09, 2009 | 1998 Jeep Grand Cherokee
Replace the ignition switch for 1998 toyota corola
first, remove the steering wheel and then remove the top and bottom covers on the steering column
Mar 14, 2009 | 1998 Toyota Corolla
Diagram for replacing an ignition switch for 1998 gmc pickup
>>>>FIRST disable the air bag system
You'll need to remove the upper and lower steering column covers.
Also all the trim under the drivers side, kneee bolster, etc...
The ignition switch has 2 screws holding it on.
Remove those screws and all related wiring harness.
Then the switch.
Here is the procedure from GM......
Place the multifunction lever in the center or the OFF position.
Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
Disconnect the battery negative cable.
Disable the SIR system.
Remove the steering wheel inflator module.
Remove the horn plunger contact.
Remove the steering wheel.
Remove the tilt wheel lever.
Remove the ignition lock cylinder. Remove the upper steering column trim cover.
Couldnt find a diagram. Hope this helps.
Jan 01, 2009 | 1998 GMC Sierra
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
181 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
