Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
1445 front deck mower 4 x 4 wont start i was wondering if it is a safety swich it wont even turn over i have checked all the fuses fuel and wiring i have done a amperage test and well over 12volts on the battery. Has to be a safety switch
nova2nv
  • 197 Answers
SOURCE: my john deere 214 won't start
The deck lift lever normally wont start lifting until you pull back at least half way.Ther are 2 sets of wires that go under the fender deck,one set goes to the seat switch and the other set goes to the neutral start switch next to the shift lever,just in front of the seat.The neutral start switch wires more than likley came loose when you pulled fender deck off.The micro switch is on the back side of plate that surrounds shift lever.
Posted on Nov 16, 2009
wireguy212
  • 1627 Answers
SOURCE: 1998 John Deere 325 belly mower 48" deck will not stay engaged.
There is a safety switch on the diferential that lets the tractor know that your not backing up that is likely defective,unplug it until you can get one in to replace it and you should be good to go.It's on th right side mid housing on the hyrostatic unit[rear diff].
Posted on Apr 25, 2010
vincob
  • 718 Answers
SOURCE: I have a Craftsman riding mower #917.257643. 15
Yes it very well could, check to see if you are making good contact with the switch first, you should hear a clicking noise when you depress the switch but that does not mean the switch is bad. If you are making good contact and hear click, check switch with volt meter to verify switch operation.
Posted on Apr 29, 2010
Testimonial: "Hey vincob, thanks for the reply. It was the switch. Still not sure why though since it is part of the starting circuit and the mower did start."
  • 760 Answers
SOURCE: scotts 2554 mower wont start
Does the engine turn over?. The pto switch you mentioned is this the POWER TAKE OFF switch? In other words starts the deck? If so, it must be off when starting the mower. Any internal combustion motor needs fuel and spark. If it cranks over check for a spark. If no spark determine if it has points or breakerless ignition. Also check magneto coil. If you have spark then, be sure fuel is getting to the carb. With today's gasoline, you can't let it sit in the tank long without adding an additive. If the PTO switch you described, is blowing a fuse, then it cold be a bad coil on the clutch. You can disconnect this coil to see if it stops blowing the fuse. you didn't mention if it is a Kohler or BS engine. Try this link:http://manuals.deere.com/cceomview/OMM141871_D0/Output/OMM141871_D014.html#34531
Posted on Jun 30, 2010
daneinwv
  • 124 Answers
SOURCE: John Deer F725 won't start
My name is Dane and I am going to assist you in solving your problem. However, I would ask that you do one check for me before we go to the seat switch procedure. Please find the starter solenoid on your mower. Make sure that the large cables coming from the battery and going to the starter are clean and tight. Make sure that your 1 (possibly 2) wires going from your switch to your solenoid are also clean and secure. Use a volt meter on DC volts, or a test light and check the small lead on the solenoid and make sure that when the parking brake is on and the Deck PTO is off, that you aren't getting 12VDC when the key switch is turned to the start position. If you have a 2-wire system, 1 of them is for ground only. 1 of the 2 wires should get 12VDC. If you get 12VDC at the small terminal of the solenoid, but no power to your starter, the solenoid is bad.
But you are probably correct that you have a problem with the seat safety switch on your lawn mower. The seat safety switch makes sure that if you are ever thrown from your mower, the engine will die.
You should check under the seat of your mower and locate a small square box with normally 2 wires connected to the end of it. While looking at the switch, press down on the back of your seat and make sure your seat is activating the switch. If not, you must get the switch correctly positioned so it makes contact and pushes the button. If you found nothing wrong there, go to the next step.
Make sure the 2 wires are connected and the wiring is in good shape. Disconnect the wires from the switch and make sure there isn't any corrosion on the terminals of the switch or the connector. After you have done this, reconnect the switch and try again to see if the mower will start.
If not, disconnect the switch again and place a jumper wire between the 2 prongs of the connector and tape them so they will not ground out on the frame. Start your mower and see if it operates correctly. If so, you have got a bad seat safety switch and it needs to be replaced. This was only a troubleshooting procedure. You should never operate a mower with this switch disconnected, because you could be seriously injured. Go buy a new switch and replace it. You will need the make, model and serial number of the mower in order to get parts.
There is a small chance that either your clutch/brake safety switch or your PTO safety switch could also be at fault. Normally they won't go bad, but will just get out of posistion so that when you activate the clutch/brake they won
Posted on Dec 11, 2010
On a John Deere 1445 turning the key on nothing works
check battery,fuses and connections --check safety switches --ignition switch and starter for power and connections
Nov 17, 2016 | John Deere Garden
Troy bilt rider won't start after filling fuel and blowing off deck. Won't even turn over even though in neutral and park. Blades are up
be sure that the connections on the safety switches are still hooked up. and the blades are in the off position. don't make much sense. this is one where you are going to have to track it down. start with the battery connections. safety switches, grounds. it is there just have to find it. check and be sure the fuse isn't blown.
Aug 14, 2016 | Troy Garden
How do I check the safety swiches on my 26jmini rider?
I take it it won't turn over or start (did you check for blown fuse first)Safety or interlock switches are a pain ,but not impossible. I use an ohm meter to check.
there is 2 to 4 wires to each switch and usually 3 switches on a mower SEAT,BRAKE,PTO or BLADE engage.
the two white wires that run to the safety switches are the mostly color used wires that complete the starter starting circut .
unplug connecter from switch and use a piece of short wire (paper clip works nice) to connect or short the white wires together do this to all safety switches and try to start.
check for broken wires and pay special attention to start selonoid witch is part of circut.
Oct 06, 2014 | Garden
Why does mower die when brake released or mower engaged?
ck your occupant (seat) switch it might have gotten dislodged or unhooked when fueling it
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Cub Cadet 2135 mower deck issue: Started OCCASIONALLY shutting off on turns and down slopes. Turned the switch off then on and it worked until another seemingly random time as above. Now, deck...
repair the seat first remove seat and reinforce metal use metal plate on top and washers on bottom or reverse make sure seat is secure so that u do not loose the ground contact on safety switch their is also a safety switch on shifter lever and brake pedal check them for rust and a tight contact
Nov 02, 2013 | Garden
Toro lx 500 riding lawn mower
check the connections from the battery to starter-check the fuses -and relays than start with the safety switches --seat-clutch-and cutter deck the safety switches are a kill switch
May 24, 2013 | Garden
Scotts S2046 Lawn Tractor electrical problem. Charged the battery, turned the switch and started right up. Put on the mower deck, turned the switch, nothing. Checked fuse, checked wiring connections but...
A couple of things -
*The battery could not be fully charged and starting depleted the battery reserve. Recharge and try again. Battery should read ~12.5volts fulled charged and not drop below about 10.5-11volts as you crank.
*Disconnect the deck and try it again. You may have cut/pinched a wire that grounded some part of the start system, There may be a connector to the deck that is not connected and your safeties are not letting it crank.
Dec 08, 2017 | Garden
We just replaced the belt on the deck of our mower. After we reattached the deck, the mower won't start. It won't even turn over. We checked the safety latch on the back of the machine, and it...
First check your battery, it should be around 12.5 volts, if not it is the battery. Because you changed the deck belt, is the mower a manual engaged deck? Make sure the safety switches are working properly. Seat switch, brake switch. When trying to start, do you get 12 volts to the starter? If not, check the 20 amp fuse.
Jan 07, 2018 | Husqvarna Zero Turn Mower Z5426
I was wondering if this mower has a fuse.It was running fine and just died.Now when I crank it nothing happens.The last time this happend I jumped it off and it started right up.Now it's not even...
it has a blade fuse by the starter solanoid. here are other places to check.loose wire at solanoid,check safety swiches.they will have power in both wires from switches
Apr 24, 2011 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
150 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
