Question about ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard
I have a asus p5sd2-vm motherboard and i disabled the internal vga card by mistake and now i have no image displayed on my screen. when u boot it beeps like 5 times. pls help , thnks.
  • ASUS Master
  • 11,800 Answers
Disconnect the monitor from the motherboard and shut it down. Open the case, find the battery and remove it for 5 minutes. Put it back, connect the monitor and boot normally.
Posted on Aug 26, 2010
My motherboard is asus P5SD2-vm. I want to buy a graphics card . which cards will support
You can look here at the ASUS site for you product:
http://www.asus.com/Motherboards/Intel_Socket_775/P5SD2VM/
As far as i can see your main board supports PCI-E x 16
Hope this was helpfull
Aug 11, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
You need to specify the exact problem.
If your PC doesn't boot up then it means that your system is not posting. This could mean that eaither your CPU or your motherboard is faulty. If you get a series of beeping sounds then you will need to replace the RAM. If your PC boots up but you get no signal to the monitor and if you were using a graphics card it now means that it may have become faulty and you will need to use onboard graphics. If you were using onboard graphics then your motherboard VGA has malfunctioned.
All in all I suggest you take it down to a PC technition to see which components are faulty.
Feb 22, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I NEED A VIDEO CARD DRIVER FOR ASUS P5SD2-VM.
ASUS P5SD2-VM Drivers.
Visit the above link from ASUS Official Support. Select the Operating System (OS) and download the required drivers.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 19, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
My pc not excepted vga driver.
Have you turned the onboard video on or off in the bios off if your installing a video card or if your unsure check in the bios .Press delete on start up to get into the bios then go into integrated peripherals.If your unsure its in the Asus motherboard manual
support.asus.com/download/download.aspx?SLanguage=en-us
Aug 06, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Vga driver is not working properly
i have asus P5SD2-VM sis672/sis968 mother board.
but my graphic card driver is not working properly , when i download any game which is of having graphic card(128mb) min requirement it does not work properly.
what should i do for this .
Jul 29, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Can i put nVIDIA geforce 8600 on my p5sd2-vm
Yes, your Asus motherboard will support the Nvidia GeForce 8600 PCI-Express graphics card.
However one thing you should consider. The 8600 card is SLI compatible but the motherboard only has one PCI-E x16 slot.
You will also need to make some changes in your bios.
In order to help you configure your system for a PCI-E graphics follow these steps.
1. Uninstall your current display driver software through windows control panel. Windows may ask you to restart your system, do not restart. Shut windows down which will shut off the system.
2. Unplug the power cable from the system & open your case.
3. Install your 8600 card. (Double check it is installed correctly & if needed has the extra power cord connected to the card.
4. Re-connect the power cord.
5. During boot up enter the bios by pressing the Delete key every couple seconds.
6. Once in the bios click the Advanced tab, see top of page 2-19 in your manual.
7. Than open Onboard Device Configuration
Open North Bridge Configuration, see page 2-22
Change Primary Graphics Adapter to [PCI-E]
Change Internal VGA to [Disable]
Change Share Memory Size to [Disable]
8. Save Bios changes & exit. Your system will auto restart.
Once windows has finished loading install the 8600 driver software & directX 10.0. You can also go to nVidia & download the latest software driver @
http://www.nvidia.com/Download/index.aspx?lang=en-us
Thanks for using FixYa!
Mike
Jun 19, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
My ASUS P5SD2-VM Is Having A No Display Problem
Make sure you disabled th eonboard video card. Some boards do it for you automatically when you install a new one and others you must remove or switch a jumper pin on the motherboard. Consult your manual for the jumper location. Sometimes you have to use the default card and go into the bios set up and disable it in there, shut down the system install the card then restart using the new card. Make sure you use the first available PCI-e slot closest to the CPU and you should be all set.If not your card may be bad.
Joe
May 28, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
If you are using the motherboards built in VGA graphic display, check your bios settings. Open your manual to page 2-22. Read the page.
Make sure you have the bios set to, Primary Graphics Adapter [PCI-E] set to, [IntVGA].
Set the internal VGA to, [Enable]. You will also need to set an amount of your system memory for the VGA to use. It is recommended if you are using Windows Vista that you increase your 1GB of system memory to, 2GB. Or instead you can buy a decent PCI-E video card that will use its own memory instead of your system memory. If you do this you'll need to change the bios settings to, Primary Graphics Adapter [PCI-E].
Also change, Share Memory Size to [Disabled].
If you need the manual for the Asus P5SD2-VM. Click on the link below;
http://support.asus.com/download/download.aspx?modelname=P5SD2-VM&SLanguage=en-us
Click the dropdown menu & click on your operating system. Than click Search. Asus list all drivers, manuals, FAQ's ect.
To view the manual you'll need Adobe Reader. You can download Adobe for free at this link;
http://www.adobe.com/products/reader/
Again, if you do not have any display & your using the built in VGA graphics card try resetting the bios. Doing this will reset the bios back to normal default settings. The bios will auto use the built in VGA. To clear the bios see page 1-22.
Mike
Apr 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
