Question about Intel Motherboard
Motherboard not showing display to the monitor, it works properly but having display problem
  • 89 Answers
If it worked before, maybe the cable is plugged out.
also if you have onboard display and seperate card try the other one.
if you can see something during bootup, then it means your resolution/refresh rate is too high for the monitor. you need to boot up in windows safe mode (press F8) and change resolution to the lowest and reboot. hope this helps.
Posted on Aug 28, 2010
K8NF4G MOTHERBOARD IS NOT WORKING
Your Video Card (Graphics Card) is probably bad. To isolate the problem connect another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays the same NO Signal Message then your video card is bad. If the Borrowed monitor displays and works correctly, then your original monitor is bad. The fact that your monitor displays the No Signal Message on it shows that the monitor is ok.
If you have a laptop, the video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 30, 2012 | Asrock K8NF4G-SATA2 Motherboard
No display on monitor
* verify if all cables are properly connected.
* Perform monitor self test by unplugging the video cable (ex.VGA) from the monitor, if you see colored bars showing on the monitor that means your monitor works fine but if there's NO colored bars showing on the monitor that means the monitor needs to be replaced.
* Go to safe mode, if successful, perform system restore. If system restore fails, run hardware diagnostic by going to F12. If no failure found, perform pc restore, if it still fails-you can reinstall you operating system.
*If all fails, you can contact your manufacturer.
***PLS NOTE that performing PC RESTORE and OPERATING SYSTEM REINSTALLATION will cause DELETION of DATA. IF YOU HAVE IMPORTANT FILES, BACK UP YOUR FILES FIRST BEFORE DOING the suggested resolution.***
Jun 04, 2011 | Intel D865GBF Motherboard
My motherboard have power but no display on display on monitor
Hi roystonfer33 ,
make sure the cable connected to your Monitor is securely connected and firmly in place. make sure the monitor is plugged into the power socket properly. if there is still no display, then maybe trying another cable for the display.
Mar 17, 2011 | Intel Motherboard
Hi fixya guys ! my lenuovo s10e doesn't show nothing on the display...lights of power, internet an so are working properly...looks like display is inactive for some reason...
You need to Connect an External Monitor To The Laptop.. (Plug A Computer Screen into the laptops serial port... ). If you get NO display on the External Monitor... Then You Have a Video Issue, The GPU has Failed.. If No Video, You can Repair the motherboard If Technically Inclined.. www.diy-laptoprepair.com
Oct 05, 2010 | Lenovo Computers & Internet
I have the same problem
Dear! If monitor showes power but not showes display its means that monitor requires heat and it very better if you can give sun-rays. I assure your monitor will work if you do that for 4 hours. Check your monitor sepreatly with another system or computer if it works that means your VGA card not supported so you should change your VGA card but first check your monitor.
Thank You
Jul 30, 2009 | ASUS P5RD1-VM Motherboard
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
Intel DG31PR Motherboard BIOS menu and motherboard LOGO not visible properly in my HP 7550 CRT MONITOR. but i plug LCD MONITOR and it show menu and logo properly. pls solve this problem to me because i...
The reason is that your CRT monitor has a low refresh rate, and the motherboard logo etc just displays for briefly seconds.....so your monitor doesn't react as soon as the signal is sent from the motherboard... Sorry you can't change monitor....
Jun 11, 2009 | Intel DG31PR Motherboard
Display problam
  1. Make sure that the monitor is turned on and has power. Make sure that the display's power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Check that all video cable connections to the computer video port and to the monitor are properly connected.
  3. Examine the pins on the video cable connector to make sure they are not bent or damaged in any way.
  4. Connect a known working display (if you have an extra one available). If you see video after doing so, replace your old display.
  5. Unplug the video cable and then turn on the monitor, check any message is showing in monitor if its shown means ur monitor is ok or else their is a problem in monitor..
  6. turn off the system and check the ram..
  7. Reset the computer...
Jan 28, 2009 | ASUS MB M3A78-EMH HDMI RT Motherboard
Vga problem in a old system
Thanks for showing your interest in Fixya. Make sure the monitor cable is plugged properly or not. Remove the monitor cable and and power on the monitor. now you could see a message saying that monitor cable is unplugged. If that message appears then monitor is functioning properly. There is a problem in your display card. Replace it with new display card. Insert the new display card into PCI slot of the motherboard. Thank you....
Sep 12, 2008 | Gigabyte Computers & Internet
Intel Motherboard Logo
52 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
