Question about Health & Beauty
MY JAZZY CHAIR HAS ONE SPEED - SLOW. WHAT HAPPEN? IS THERE A FIX?.
  • ANDREW DOPPEL Aug 27, 2010
    IT IS A 1113 MODEL. LIGHTS ON CONTROLLER INDICATE A FULLY CHARGE BATTERY?????. METER INDICATES A FULL CHARGE BATTERY. AT THE MOMENT I AM USING A EXTERNAL CHARGER AND IT SEEMS TO BE CHaRGING - BUT.....
  • 17,970 Answers
They never made a chair that was THAT slow! So it has to be set slower in its programming. Thats easy to fix.
See here powerchair-programming. You will need a programmmer or some dealer / workshop that has one.
Sometimes if people are weal/frail/not good with control, for any number of reasons speed will be "turned down" as will many other parameters.
As far as dealers / service etc go, I have been looking for years. Never found one with any clue yet so will leave that to others to answer.
Apparently it uses a small 40 amp PG GC CONTROLLER in the US (may be different here) which isnt shown on their website pgdt.co.uk so give them a call. They can reprogram or sell you a programmer but not cheap. A dealer is easier and takes 1 minute, It should do 4mph - are you sure it doesent? Pride dont make these systems, but can "rebrand" them. Never saw a PG GC CONTROLLER... Even on Penny and Giles website who actually make them.
Hope helps.
Posted on Aug 27, 2010
Pride z chair goes forward very slow, no speed but turns faster . whats wrong?
The Brakes could be hanging up causing bad drag on the system. The Joystick gimbal maybe wearing out. The programmer may need adjustment, but I would look at the brakes first. Strege Mobility
Apr 28, 2016 | Pride Jazzy Z-Chair Z-CHAIR
Why is my merits DL 5.2i stuck in low speed ?
You may have a thermal rollback issue. Try charging the chair overnight and leave the controller on while charging. This will give the control module/joystick time to reset themselves. Thermal rollback happens when a certain temperature in the motors is reached. The system shuts itself down to protect from damage.
Apr 26, 2014 | Select Jazzy Used Electric Wheelchair
Will only work at a slow speed speed was working fine then next day dead slow is all it will do
I had a same problem but worked fine when I installed mackeper. Its easy to remove errors you may have which slowed it. Try it out and let us know the outcome. Here is the download link to it. Good Luck http://bit.ly/1aHCD0n
Aug 31, 2013 | Pride Jazzy 1113 Power Chair
The lights that indicate the speed are flashing and the wheelchair only will go very slow. What does that indicate. Sometimes when I fiddle wit5h the seat up and down it will go right but then next time it...
there is a switch or potentiometer on your seat, that sends a signal to the chair to drive slowely when tilted or reclined, this is called drive lockout, you may have a malfunction or the provider didn't set it to a setting for your needs, contact them and ask for repair or reprograming which ever is the case, if that is a problem call 1-800-800-8586 talk to jazzy tech support they have a company called road runner for repairs etc.
Dec 23, 2012 | Pride Jazzy 1103 Ultra Standard Power...
My brother who died about 2 years ago left a jazzy 1103 ultra mobility chair. Unfortunatley I cannot work out how to start it. Its all charged but can't find ingnition. Can you help please Anne ...
ana at the top of the joystick is the on/off button just push it and the lights sshould come on the battery level lights should all light up and you can set the speed with the two buttons on each side the left to slow down and the right to speed up. When all the speed lights are lit you are at max speed Hope this helps
Apr 19, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Have a jazzy 1113. The speed profile lights flash then the chair shuts off. The batteries show full.
The flash of the speed lights indicate that you are in the charger inhibit mode and if the charger is not plugged in then you have a problem that needs to be checked by a tech or your provider that sold you your chair Sorry I don't have a quick fix
Sep 25, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Can the speed of the Jazzy Power chair be increased beyond the setting on the armrest remote controller?
Make sure that your tires are properly inflated and that you are not carrying more weight than the power chair will allow and that your batteries are fully charged.
If you got your chair second hand, sometimes the previous owner has the technician change the controller settings to "dampen" it to slow it down to allow them greater response time and control. The technician can reprogram the controller to take it back to 100%. If you got the power chair new, it should be at 100% already.
Take it easy, HotRod. It's a medical device, not a car!
Jul 20, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
My father has a jazzy select power chair. The spe...
You will have to take it to a mobility dealer to have it programmed
May 14, 2010 | Health & Beauty
New batteries chair slow
Instruction Manual:www.FixYa.com/Insrtuction+Manuals & for extra info type in a brouser: local dealer for your product giving its name & it maybe a seperate box for you to enter your Post Code,enabling easier searching for you.
May 12, 2010 | Select Jazzy Used Electric Wheelchair
MY CHAIR WILL NOT CHANGE SPEEDS IT IS VERY SLOW AND WILL NOT INCREASE SPEED AT ALL. LIGHTS ON POWER LIGHT INDICATOR FLASHES CONTINUOULSLY
Your batteries are bad or not charged up is it only 1 red light flashing or is it all power lights flashing 1 red means not enough charge. all means internal problem with joy stick
Mar 05, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Health & Beauty Logo
71 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
