Question about Zenith C27A24T 27" TV
When you first turn ythe set on, it does not have any sound. If you turn it side ways or put your hand on the set it works, but as soon as you remove your hand it quits. Sometimes banging on it, makes the sound come on.
  • 32 Answers
Hopefully there is some bad contacts between the sound IC and the print board. you may check and do some soldering on it.
90% of the Zenith i work on has the same problems and solution. be sure to do a complete check on loose connections in the set once you open the system.
Posted on Aug 26, 2010
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
Why is car vibrating loud and hard when I turn the wheel towards the right?
sounds like its the wheel bearing assembly on one of the left hand side wheels recheck that there is no play on those wheels when jacked up off the ground and spin both wheels by hand .......your sure to feel a roughness on the problem wheel on fast rotation by hand
Aug 19, 2014 | 1999 Chrysler Sebring
I hooked up 1 10" type r to my 600w sony xplode
How many ohms is the speaker? You have the amp bridged going into the sub? You have the negative of one side hooked up to the negative and the positive on the other side hooked up to the positive?
It says that it is bridgable at 4 ohms. What about the input? Set your stereo about half way up. Then turn your amps gain up slowly until it is where you want to listen to it normally. Not to loud. Then when you turn it up it isn't too much.
But it sounds like you have way too much power for one speaker. Especially a ten. It takes two tens to equal one 12.
Dec 17, 2010 | Sony Car Audio & Video
I have a audi a4 1.8t can turn blower all the way up wen car is not running wen car is running as soon as I turn on fan lowest setting the fuse blows thank you for your help please email at...
It sounds like you have a bad connection out side under the hook upper left side on the fire wall is the blower motor there are two sets of wires going to this one set is for the motor witch works the other set controls the resistors for the differant fan speeds Try unpluging those wires its the larger of the two connectors and has more wires going to it clean the connections if this dosn;t fix the problem you may need to replace the resistor board in side the house But most of the time its just a pour connection
Nov 24, 2010 | 1998 Audi A4
My 650 dragstar starts fine but cuts out as soon as I engage gear. Have checked the side stand switch and it is working fine. Any ideas?
The side stand switch can work in cojunction with a clutch switch.
It still sounds like a side stand problem, check the wires and plug, use a multi meter to check the switch. If you didnt check it that way.
The switch may work but the stand is not pushing the contact far enough
Does the neutral light work correctly?
Assuming it is not clutch drag with the bike jumping and stalling when put in gear
May 13, 2010 | 1997 Yamaha XVS 650 Dragstar
I WANT TO PUT IN A SOUND CARD ON MSI N1996 MOTHERBOARD
Although I'm not familiar with that motherboard the usual way to disable the onboard sound is;
Enter the bios by pressing the Delete key or F2 when the machine starts to boot.
Go to the Integrated Peripherals section and find the On-Board line and change it to disable.
Feb 02, 2010 | Computers & Internet
Loud ''stalling'' noise from heating side
May need a run capacitor.compressor can't work against the load. The capacitor isn't very expensive. Chk ythe fans first, they tend to seize up causing high pressures and the sound of slowing dow or stalling. GL-Ned-
Oct 30, 2009 | Heating & Cooling
Clicking noise like clock in the dash.
That is the body computer making noise. It has a time out feature that turns the auto lights off after 30-90 seconds, and the interior lights are the same way. Sounds like it may be going bad.
Jun 20, 2009 | 2002 Ford F250 Super Duty SuperCab
Gas leak as soon as engine starts
needs a good carb cleaning an replace float needle&seat on ythe eaking carbl
Mar 29, 2009 | Honda XR 200 Motorcycles
2002 jeep grand cherokee heater doesn't blow hot
If ythe heater core is not bad then I would replace the thermostat, this will stop the warm coolant running up to your engine go to the heater core.
Feb 01, 2009 | 2002 Jeep Grand Cherokee
Zenith C27A24T 27" TV Logo
22 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
