Question about GPS
The cd70 navi avoids motorway how can the setting be changed?
Alternative route given
explain avoiding motorways . that would be highways and that is where we drive here. not overland
Jul 09, 2016 | Garmin nuvi GPS
My sat navigation never brings me on the motorway.
Check the Avoidances setting.
To locate the Avoidance menu:
nuvi 200, 205, 405, 500, 700, 705, 800, 805, 1100, 1200, 1300, 1400, 1690, 5000 series, zumo 220, 660, and 665 devices:
  1. Touch Tools
  2. Touch Settings
  3. Touch Navigation
  4. Touch Avoidances
  5. Touch the desired Avoidance to enable it
Mar 09, 2016 | GPS
Site that i should open my mms
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The phone has a four-way directional Navi key and two soft keys on either side of this. The Navi key can also be pressed in to select options.
  1. Press Menu (press Navi key)
  2. Highlight Settings and Select (press Navi key)
  3. Highlight Configuration and Select (press Navi key)
  4. Highlight Personal configuartion settings and Select (press Navi key)
  5. Press Add new(press Navi key)
  6. Highlight Multiedia msg. and Select (press Navi key)
  7. Highlight Account Name and Select(press Navi key), enter giffgaff - MMS then OK (press Navi Key).
  8. Highlight Server address and Select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002 and OK (press Navi key).
  9. Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
  10. Highlight Access point settings and Select (press Navi key)
  11. Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
  12. Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
  13. Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
  14. Highlight Bearer settings and Select (press Navi key)
  15. Highlight Packet data access point and Select(press Navi key), enter giffgaff.com and OK (press Navi key)
  16. Skip past Network type this should be set to IPv4
  17. Skip past Authentication type, this should be set as Normal
  18. Highlight Username and Select (press Navi key), enter giffgaff and OK (press Navi key)
  19. Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
  20. Press Back (right soft key) six times
  21. Highlight Messaging and Select (press Navi key)
  22. Highlight More and Select (press Navi key)
  23. Highlight Message settings and Select (press Navi key)
  24. Highlight Multimedia msgs. and Select (press Navi key)
  25. Highlight Configuration and Select (press Navi key)
  26. Highlight Configuration and Select (press Navi key), highlight Personal config. and Select (press Navi key)
  27. Highlight Account and Select (press Navi key)
  28. Highlight giffgaff - MMS and Select (press Navi key)
  29. Press the right soft key five times to get back to the standby screen
Please switch your handset off and back on again before using these settings.
The settings are now complete.
hope that helps
May 29, 2013 | Nokia C1 Cell Phone
Does not internet
Hi jobmasai,
you may wanna try this:
Nokia 2330 GPRS and WAP / Internet Settings
1.Press Menu (press Navi key)
2.Highlight Settings and Select (press Navi key)
3.Highlight Configuration and Select (press Navi key)
4.Highlight Personal configuartion settings and Select (press Navi key)
5.Press Add new (Navi key)
6.Highlight Web and Select (press Navi key)
7.Highlight Account Name and Select (press Navi key), enter giffgaff WAP GPRS then OK (press Navi Key).
8.Highlight Homepage and Select (press Navi key), enter http://giffgaff.com/mobile then OK (press Navi Key)
9.Highlight User name and Select (press Navi key), enter giffgaff then OK (press Navi key)
10.Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
11.Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
12.Highlight Access point settings and Select (press Navi key)
13.Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
14.Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
15.Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
16.Highlight Bearer settings and Select (press Navi key)
17.Highlight Packet data access point and Select (press Navi key), enter giffgaff.com and OK (press Navi key)
18.Skip past Network type this should be set to IPv4
19.Skip past Authentication type, this should be set as Normal
20.Highlight User name and Select (press Navi key), enter giffgaff and OK (press Navi key)
21.Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
22.Press Back three times (right soft key)
23.Highlight giffgaff WAP GPRS and press Options (left soft key)
24.Highlight Activate and Select (press Navi Key)
25.Press Back (right soft key) four times.
Apr 14, 2011 | Nokia Classic 2330 Cell Phone
I cant receive mms
The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this and 4 additional soft keys either side of the keypad. The Navi key can also be pressed in to select options.
1. Select 'Menu' (press Navi Key).
2. Scroll to 'Settings' and select (press Navi key).
3. Scroll to 'Configuration' select (press Navi key).
4. Scroll to 'Personal configuration settings' and select (press Navi key).
5. Press 'Options' (left softkey) highlight 'Add new' select (press Navi key).
6. Highlight 'Multimedia msg.' and select (press Navi key).
7. Highlight 'Account Name' select (press Navi key), enter 'giffgaff MMS' then 'OK' (press Navi Key).
8. Highlight 'Server address' select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002' and 'OK' (press Navi Key).
9. Highlight 'Use preferred access point' and select (press Navi key), highlight 'No' and 'Select' (press Navi key).
10. Highlight 'Access point settings' and select (press Navi key).
11. Highlight 'Proxy' select (press Navi key), Highlight 'Enable' and select (press Navi key).
12. Highlight 'Proxy address' select (press Navi key), enter '193.113.200.195' and 'OK' (press Navi key).
13. Highlight 'Proxy port' select (press Navi key), enter '8080' and 'OK' (press Navi key).
14. Ignore 'Data bearer' as this is set at 'Packet data'.
15. Highlight 'Bearer settings' and select (press Navi key).
16. Highlight 'Packet data access point' select (press Navi key), enter 'giffgaff.com' and 'OK' (press Navi key).
17. Ignore 'Network type' as set at 'IPv4'.
18. Ignore 'Authentication type' as set at 'Normal'.
19. Highlight 'User name' select (press Navi key), enter 'giffgaff' and 'OK' (press Navi key).
20. Highlight 'Password' and select (press Navi key), enter 'password' then 'OK', verify password and again select 'OK' (press Navi Key).
21. Press 'Back' (right softkey) 6 times to get to the main menu.
22. Highlight 'Messaging' and select (press Navi key).
23. Scroll to 'Message settings' and select (press Navi key).
24. Highlight 'Multimedia msgs.' and select (press Navi key).
25. Ignore 'Delivery reports' as preset to 'No'.
26. Ignore 'Image size' as preset to '640x480'.
27. Ignore 'Default slide timing' as preset to '00:08'.
28. Ignore 'Allow multimedia reception' as preset to 'Yes'.
29. Ignore 'Incoming multimedia messages' as preset to 'Retrieve'.
30. Ignore 'Allow adverts' as preset to 'Yes'.
31. Highlight 'Configuration settings' and select (press Navi key).
32. Ignore 'Configuration' as this will change to 'Personal config.' with the next step.
33. Highlight 'Account' and select (press Navi key).
34. Highlight 'giffgaff MMS' and select (press Navi key).
35. Press the right softkey 5 times to get back to the standby screen.
The MMS settings are now complete.
Feb 07, 2011 | Nokia 6070 Cellular Phone
I programed the post code of ferry terminal in southampton, fully expecting to bypass town on motorways but Garmin took me right through busy town centre - held up for hours. Why did it not go via...
you probably have it avoided on your Navigating....... try going to Tools.... Settings.... Navigation...
under Route preference chose faster time...
under Avoidances make sure you dont have motorway (highway) checked to avoid
Nov 12, 2010 | Garmin GPS
How to avoid motorways
Go to Tools .....Settings....Navigation....under Avoidances check what you want to avoid
Nov 09, 2010 | Garmin n?vi 265WT Car GPS Receiver
How do iget my gps to use motorways it always seems to avoid them
Go to Tools.... Settings..... Navigation.....
Route Preference click to change
Avoidances Enabled
click to change uncheck Highway
the only Avoidances I use are U-turns...Traffic...CarPool Lanes and Unpaved Roads
Love my Nuvi760
Jun 14, 2010 | Garmin Nuvi 660 GPS Receiver
Toshiba 3510c , error code cd70
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Aug 11, 2009 | Toshiba E-STUDIO 650 Copier
Navi g tells you to turn when you're right on the corner-too late
Hi
In the actual menu of your Nuvi there are different settings for getting to your destination via either
a) fastest route
b) shortest distance
Unfortunately quite often when the Nuvi is set to fastest route it will do all it can to get you onto the motorway or a main road as this is the way the software is set up. When in fastest route mode it cannot figure out that to go on the motorway in this instance is not the most convenient route for you to take at all.
If you change to shortest distance mode (its under the navigation menu I think) you will find it will take you by the route to your Nannas you would normally expect to go.
Sometimes this function is hard to work out as to which is the appropriate setting for a particular journey - you will need to experiment a bit with it but the general rule is if it is in fastest route mode it will look for motorways and main roads and ignore the convenient little back roads that we all know in our own locality.
You may find as general rule that if you plan a journey to somewhere thats within your local area its better to select shortest distance mode.
Fastest route may work better for longer journeys.
Hope this helps. Please do rate my answer. Many Thanks.
Jul 28, 2009 | GPS
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
