My house airconditioner is making a noise and spitting water out of the vent into my house is that normal?
    Problem Solver:
  • 19 Answers
No this is not normal. You can try cleaning your condensate drain. Otherwise call a professional.
Posted on Aug 26, 2010
Portable ac Danby Premiere DPA110CB5BP spitting water while it fans.
If you are referring to the unit doing this on the outside of the structure, this is normal. the "Hamster Wheel" is designed to carry a small amount of water and create a light amount of water to go onto the condenser to help with the evaporation and cooling process. If this is on the inside of the structure, the unit may not be level or another issue causing improper drainage.
Aug 01, 2017 | Danby Heating & Cooling
Kenmore dishwasher making "spitting" or "sputtering" noise during operation
The easiest way to confirm if the arms are blocked is by turning all the arms in the machine to a certain same position and running the machine for a few minutes in its wash cycle. Open the door and see if the arms have moved. If not, check all the holes in the arms for blockages. Sometimes its very difficult to clean them. You may have to poke a pin or something into hole and then shake the obstruction out through the large inlet hole under the spray arm itself.
Dec 23, 2014 | Kenmore Dishwashers
Super s overflow hose makes awlful sputtering noises every twenty minutes
Thats because they have the air pump set to run every 20 minutes to inject into to the tank. When this happens the unit will run to drain slightly while the pump is cycling causing the "spitting" of water.
RJH2O
Dec 07, 2013 | Culligan 34" Whole House Water Filter...
Dirty Water & gurggling & spitting sounds coming from toilets
I assume that the toilet flushes and refills with clean water? Check the vent- for debris or critters. If nothing is apparent, stick a hose in it and run water down the vent.
May 30, 2017 | Home
Droplets of water are coming from the vents and it's making a noise like something is rattling around inside. What could this be?
The problem with this unit is that the evaporator, or the part of the air conditioner that 'creates' the colder air is not draining correctly. Pertaining to a window unit, it needs to be installed correctly with the correct amount of tilt toward outside, to allow the evaporator condensation water to drain. You may also want to check to make sure there aren't any plugged drain holes in the air conditioner housing.
The rattling you hear is most likely the blower fan spinning against the held water inside the unit.
I hope this helps! :)
Sep 01, 2009 | Heating & Cooling
My window air conditioner keeps freezing and leaking water does this mean i need a new part for it? the model number is FAA060P7A5
It is normal for airconditioner to have condensation. Just make sure the water don't go in the house. LOL
Aug 15, 2009 | Heating & Cooling
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
Window unit just started spitting a little water and making a noise like when something is too tight a fit, a rubbing noise. just started minutes ago. it's raining but, what could of happened?
Make sure the window unit is evenly placed inside the window frame.Just a slight twisting of the housing will cause the fan blade to scrape the housing. Make sure that the fan blade has no come loose from the fan motor shaft if that does not solve the problem. Also make sure the window unit tilts slightly downward so that any water from the condensate produced inside the home on the condenser coil can drain down the slope to the outsidelike the way explained. I have also seen units that were positioned correctly but the drain trough is blocked and will not allow the water to drain outside the house. Let Me Know, Thanks, Sea Breeze
May 15, 2009 | Haier hwr10xc6 Air Conditioner
Ac. spits out water in the front and ac., is tilted back ,gets worse as it runs
You need to blow into the drainpipe on the outside of the building to clear the blocked drainpan outlet. This just to make sure that your drain is clear. If the problem persists. Check that the filter is clean. This can also happen if you are slightly short of refrigerant and running the aircon at 18C or lower on a humid day.
Apr 28, 2009 | Heating & Cooling
Heating & Cooling Logo
174 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
