Question about Whirlpool Dishwashers
Dishwasher will not pump out-whirlpool gold - Whirlpool Dishwashers
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Aug 29, 2010
My Whirlpool gold dishwasher will not drain completly, and if it does, it's very slow
If there are no obstructions in the discharge hose then I belive that the pump is most likely the blame. Something may be caught up in the impellers of the pump not allowing it to create suction. You can also look to see if the electrical connection on the pump has in some way become disconnected via a plug or loose wire.
Jan 04, 2015 | Whirlpool Gold GU2475XTV Builtin...
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool gold dishwasher model Quiet Partner 3. The top rack is not cleaning the dishes very well. We live in the country and have hard water. I am wondering if there could be a buildup of some...
if it is just affecting the upper rack i doubt it is just a plugged spray arm (though i could be wrong). more likely than not you have a blockage on the intake of your spray pump motor. a series of bones, toothpicks, foreign material, etc could be blocking the entrance of the pump causing it to starve for water so to speak.
you will more than likely need to remove the lower rack and spray arm to be able to disassemble the strainer and gain access to the sump.
a complete model number would help bunches to.. alas
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a GU1200XTKQ0 Whirlpool Gold Dishwasher. I
If you have a Wet/Dry Vacuum, then you can use that to **** up any debris you see in the bottom of the Dishwasher. Make sure you remove the paper filter from the vacuum so it does not get damaged from the water in the bottom of the Dishwasher. I use the vacuum trick to clean up the muck from the pump area and it works well.
Apr 04, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water does not drain out completely on our model GU1500 Whirlpool Gold dishwasher. This happens about every 4th time we run it. Water is cloudy and about 2" deep in bottom after cycle ends.
there is a PROBLEM with the pump.it is most likely clogged,in which case,it must be removed and cleaned.the pump might also be faulty,and so must be replaced.
Oct 24, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold gu1200
Sounds like glass fragments against the pump impeller. This may jam the impeller and reduce water pump volume giving poor wash performance and possible inability to evacuate the wash tub. It will not go away and may cause the impeller to fail. Remove screens and get the glass out. Do not poke around with your fingers unless you like cuts.
Sep 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My gold quite 3 rattles when draining. The
Turn the plastic center screw counter clockwise. The bottom spray bar is supposed to be loose so it will rotate under water pressure. Rattling maybe coming from diswasher/cabinet contact, or debris caught in the main pump or drain pump, or the food disposer.
Mar 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
50 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
