Question about LG 22" FLATRON LCD Monitor
How do you tilt screen back - LG 22" FLATRON LCD Monitor
    President:
  • 2,571 Answers
Just get hold of the top and bottom of the monitor and push it back or forward.
If it wont tilt with minimum effort, it may not have a tilt function, or it is broken, i have never had any problems with any monitor
Posted on Aug 26, 2010
Why does the touchscreen keep tilting g upward each time I put my car in re else?
read the instructions again It sounds like that might be an automatic feature to get it out of your vision while backing .
Jul 20, 2015 | Crown Ouku 7" Double 2 Din In Dash Car Cd...
Touchsmart HP laptop screen goes white when I tilt the screen
Very likely that the screen cable is damaged around hinge area. It has to be replaced. (just the cable, not the whole screen).
Dec 29, 2013 | HP Pavilion TouchSmart 14 Sleekbook with...
Screen goes blank on Samsung LCD TV. Comes back on if tilt or move screen.
I'm gonna go out on a limb and say you may have a LCD tab(s) that are failing.
Jan 26, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
Sony KV27FS120 Tilt correction
Use the tilt adjustment in the menu system or if that doesn't go far enough, move the metallic object, (loudspeaker etc) further away from the screen.
Jul 26, 2017 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Screen tiled and i can't move it back
Try reseting the settings to factory defauts in the monitors user menu. You can get more details from the manual on this.
If reseting the settings doesnt work. Could you take a photo so we would have a better understanding of the problem :-)
Or do you mean the screen is fysically tilted? If parts are broken and you are unable to move the screen, then I cant offer much help, you could contact acer for support or to take it to a local pc shop for analysis.
Feb 08, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Tilted Screen
Yes, there is a tilt adjust,but you should have service manual to guide you....it requires some diassembly / access in back of set.....................T.
Dec 20, 2007 | Samsung HC-R4755W 47" HDTV
Kenwood DNX7100 screen won't tilt back up after putting in CD
Yes opening the unit with the eject button then manually closing the unit halfwaly, and disconecting the battery for like 30 secs.... Here
Dec 04, 2007 | Kenwood DNX7100 Car Video Player
Monitor is tilted forward and wont tip back
it will tilt back, just make sure the stand is in the forward most position and not turned and hold the screen at top and push while at the same time pull at the bottom, it will be quite stiff.
Sep 23, 2007 | Compaq fs740 17" CRT Monitor
LG 22" FLATRON LCD Monitor Logo
190 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
