Whirlpool Duet washer control lock light on. When I push the pause and control on buttons at the same time I get the numbers back on the screen and the heavy duty light flashes. If I push anything all the lights go out but the control lock light.
  • judah-777 Apr 11, 2009
    the control light stays on and no matter what button I push I can't get the control button to work. I too have the Whirlpool Duet washing machine. I didn't do anything to cause this. I went in to do laundry and the light was on! Help!
    Genius:
  • 1,073 Answers
Hold in the signal button for 4 seconds and it will unlock the control
Posted on May 06, 2008
ThThe light control light on but the washing maching wont run the lock is open
Posted on Dec 20, 2012
2 Suggested Answers
SOURCE: whirlpool Duet
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Posted on Feb 03, 2008
My washing machine says control locked
Hello there
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front load washer
If you push the end of cycle button for 5-6 secs. It turns the control lock on, do it again, and it turns the control lock off, on both the washer and the dryer
Mar 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The control lock is on. I have tried unplugging it and pushing the cancel pause button and it is still on and I can't do anything because because it is all locked.
Hello
To unlock the controls you can reset the control by pressing the END OF CYCLE button and hold it for 15seconds. This is a common issue with whirlpool duet washers. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you get control lock off whirlpool duet washing machine
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock on washer - How do you turn it off
PRESS AND HOLD END OF CYCLE SIGNAL BUTTON 3-5 SECONDS
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Whirlpool Washer
You need to go to the right, to the end of cycle signal volume control button. Push it and hold it until the beep and it will go off. This is the "child safety" feature so that little ones won't interrupt your wash when they push the buttons. (and they will)
Michell~
Jul 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer
Press and hold the end of cycle button for 3 seconds..
Jul 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wont start
if it is duet hold the end of the cyle button and it will re set
Dec 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet model number GHW9100LW2-control lock button stuck on red, cant do anything else. Tried pushing the pause cancel button nothing......An ideas? Thanks!
Uppi
Sep 07, 2007 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
605 people viewed this question
Top Washing Machines Experts
