Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
My brand new dishwasher is leaking water from the bottom of the door. What could be wrong??
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
rtsy4w7a
Posted on Sep 29, 2010
Just installed the dishwasher and it is leaking from the the two front corners of the door
I dont know what brand your dishwasher is, but if it is leaking from the two bottom corners it is not level. If the back is higher than the front, the water will drip out of the bottom corners of the door. Raise the front feet up so that the edge of the door is flush with the cabinet doors from the top to the bottom.
Nov 20, 2010 | Dishwashers
Brand new kenmore dishwasher leaking out the front
Check the door gasket for uniform seating. Align it. If this does not solve the problem, contact the service provider. He may change the gasket or do the corrective action.
May 25, 2010 | Kenmore 13743 Staimless Steel Built-in...
Why is water leaking from the bottom of the door? Do I need a new seal?
Hi, Yes... Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
May 20, 2010 | Amana 24 in. ADU5000D Built-in Dishwasher
Brand new kenmore leaking at bottom left door
Water level may be too high...
Check door seal by draging a strip of paper through with seal closed.
Dec 12, 2009 | Kenmore Dishwashers
Water leaks past the seal
In most dishwashers is does not matter, what I am saying is the door does not seal to the unit like you think it would, there is not tight seal like on a refrigerator, in most cases the bottom lip of the door just closes over a lip on the tub of the washer. So for people that add to much detergent or the wrong kind can get suds coming out of the bottom. There is a float valve that stops the washer from overflowing(overfilling)
in the bottom, kind of looks like a mushroom, check around this to make sure nothing stuck around it or under it. It should be able to move up and down freely. Any questions please post back,everyone is happy to help.
Mar 26, 2009 | Frigidaire Dishwashers
Leaky Dishwasher
The dishwasher was installed with a defective fill valve or the valve was damaged during installation of the dishwasher.
Jun 23, 2017 | Magic Chef 24 in. DC4000 Free-standing...
Brand new dishwasher installed and water leaks out bottom of door
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher leaks out front
If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and cause water to spill over out the bottom of th door. Use rinse-aid for better drying performance
May 29, 2008 | Dishwashers
Bosch Dishwasher door leaking at bottom, brand new.
Um rough to diagnose without seeing it but there should be a rubber gasket along the bottom of the door. And does the door panel hit the side of the tub when u shut the door? It shouldnt
Nov 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
117 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
