I have an AMU monitor and i have a problem, when i turn it on it says that there is no RBG signal! and then goes into standby mode. i have tryed several other monitors on my computer tower and i get the same result, can anyone help me?
  • 61 Answers
There is no signal coming out. Try inspecting the video card. You can always reset the BIOS of the motherboard by removing the small battery and replacing it.
Posted on Aug 26, 2010
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Monitor is switching off immediately after system is switched on. Again when monitor is switched on, images appear for about 3 seconds and again monitor switches off.pl give the solution.
You need to determine if you is turning off or going into standby mode. When your monitor shuts off, the power light will turn orange if it is in standby or the light will turn completely off if the monitor turns off. If your monitor goes to standby, that means that your monitor is losing signal which indicates a problem with your PC. #1 Make sure cable is firmly secured and both screws are tight #2 Check your video card make sure that it is firmly in its slot. Take it out and put it back in. *as long as your computer is open give it a good cleaning with compressed air* If those things check out it is possible that your video card has failed and needs to be replaced.
If your monitor is powering off #1Check plugins- try something else (i.e. lamp) in the outlet #2 Try your PC's power cord in your monitor
Oct 21, 2010 | ViewSonic Computers & Internet
Does not receive signal. Power saving Mode appears and that it switches to standby,
have you tried turning it on in safe mode? The F8 key at the top of the keyboard should give you that mode. Once you turn the computer on, continuously press F8 until it switches to safe mode-then go into 'control panel' and check settings for your monitor.
May 18, 2010 | LG L1717S-BN 17" LCD Monitor
No signal sent to monitor
  • when you turn on computer. after sometime your monitor goes to standby mode and monitor light colour will be orange it means problem with your computer not monitor.
  • After this You Check your VGA Card.
  • When you turn on computer is there any beep.
  • After this also check your RAM.
  • May be problem with your RAM.
Try this Solution
Mar 13, 2010 | ASUS P4S533-MX Motherboard
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
My monitor gets switched off when i connect to cpu,the moment i disconnect it from cpu,its switches on automatically.what may be the problem?
One of two things:
1.) Your video card is 'stuck' in standby mode, which in turn sends a signal putting the monitor in low power 'standby' mode as well. When you disconnect it, the monitor returns to normal 'on' mode. Rebooting the PC should correct this issue.
2.) Your resolution or refresh rate are set outside the range supported by the monitor. When you connect the monitor, it starts receiving a signal that it can't display, so it simply turns off. You'll need to reboot the PC and press F8 quickly to bot into safe mode and correct the monitor settings.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My monitor says no signal
You'll need to check the cable connections and the computer that it is attached to. The monitor may be going into standby mode because the computer went into Suspended/Hibernate mode. Try restarting the computer. If you're unable to do this, try a hard power off and then try to turn it back on.
Sep 17, 2008 | E-Machines eMachines Monitor E15T4
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
What is the triggering signal to power on the monitor?
Most modern monitors use the Horizontal sync line to determine when to go to standby.
Aug 18, 2006 | BenQ V773 17" CRT Monitor
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
