Question about Garden
Have a Weedeater BV185 with WA229 carb. ****** has never run right since the day I bought it. After sitting for a couple years the fuel line in the tank dissolved. Replaced those and I think I have them on correctly. The small diameter on goes on the carb port away from the primer bulb and the larger diameter one goes on the port near the bulb. I put the filter on the smaller line. I disassembled the carb and all the gaskets look good, the fuel pump diaphragm looks fine. Pulled the needle valve and cleaned it. A little gas directly in the cylinder and it will fire and the plug has spark. When I try to prime it, I get nothing in the bulb. The fuel line is full of gas, the return is full of air. No smell of fuel in the carb. Any thoghts as to when I can do to get it started?
  • 2 more comments
  • dan0256 Aug 26, 2010
    I would like to know if the primeer bulb should fill with gas. It seems to me that it's not getting fuel. Should the bulb fill with fuel? should the return have fuel in it? If I prime it a dozen time should I not smell gas (flooding)?
    How do I check the timing?
  • dan0256 Aug 27, 2010
    Check gap - timing is non-adjustable.
    I agree that there is a fuel restriction. I just can't find where. I did remove the needle, but I didn't see a screen. It all went back the way it came out. I'll double check again tomorrow. See if I can find this screen.
    President:
  • 2,501 Answers
You have been very thorough in maintaining the carburretta and since you have had problems ever since you bought it, you should look elsewhere to solve the problem.
I suggest that you check the spark gap on the plug and check the timing. An incorrect spark gap effectively alters the timing and if the basic setting of the spark gap is wrong then starting can be effected.
Posted on Aug 26, 2010
  • 1 more comment
  • David Tolond Aug 27, 2010
    I don't know your machine well enough to give any advice on how to check the timing. Does your manual say anything on this?
    (Timing usually involves using a strobe light shining on magneto when the machine is running0>
    Manual says timing is fixed and not adjustable.
    I'll check the spark gap, but I still think it's not priming right.
    Spark plug gap is correct at .025
Tip
To every one that owns small engines,mowers,weedeaters,ect
ah spring is in there air time to break out the lawnmower,weedeater,chainsaw,ect somebeach it worked great the last time I used it pull,pull,whats going on pulled so hard i broke the cord got gas went and bought a new plug still nothing swich on fullchoke honey weedeater gone bad honey i need a new chain saw cheaper to by a new one than to put it in the shop now the real problem when you put up that weedeater,that cool tiller,that awsom chainsaw the one thing you did not do is drain the exess fuel when you store this equiptment for extended periods of time drain the gas in a safe manor start that weedeater , chainsaw, ect and run it completly out of fuel ya see when gas or oil&gas mixtuers sit they evaporate leaving a laquor like substance gumming up your fuel/air mixture needle&seat floats nasty stuf next thing you know theres me driving through your neighborhood picking up your weedeater,that cool rototiller ,nice lawnmower dude yess now rebulding a carborator can be a pain sometimes but if you have patients it can be done get a can of carborator cleaner with extension hose clean the outside of the carb so you can see what your doing and not getting trash where it dosent belong check your fuel lines they tend to get hard and crumble take one hose off at a time some only have one but most have two spray cleaner back twords tank see cleaner in tank cool next spray cleaner into fuel inlet a couple of bursts reconect hosess spray cleaner down carb air intake pulling on throttle to open choke flap for a deeper clean now assemble go through normal starting prociedures still a problem now it gets deep you have air/fuel mixtures screws ,diaframes if you dont feel safe about getting deeper into that carb go to lawn mower shop with ser# how many cc maker of carb stamped on carb most likley a warbro tell them you want a rebuild kit not expencive and schematic I would like to tell you a lot more but there are so many varables its crazy so going back to the begining DRAIN THAT EXCESS FUEL START THAT ENGINE TILL IT COMPLETELY RUNS OUT BEFOUR YOU STORE you will be a lot happier so will your wife .!!!zaper!!!
on Apr 14, 2010 | Garden
When I turn on my bike, gas runs out of the bottom of the bike. It is a 89 Gold Wing. IT has been sitting maybe a couple years. I bought it like this. I'm going to start a tare down this weekend. Just...
I would have say the float in your carb is stuck. Take the bowl off the bottom and see if your float needle is sticking if not check your fuel line's .
Oct 16, 2013 | Honda GL 1500 Gold Wing Motorcycles
50cc scooter repair
Hi, Anonymous if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
1. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
2. Remove your air cleaner and clean and re-oil per Mfg. specifications.
3. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
4. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
5. Replace spark plug with a new one and check for spark.
For more information about your question please visit the website below. Good luck and have a nice day.
Toyota 3A Engine start up after sitting for 10 years prep work Vespa Scooter starts after 10 years of sitting
Sep 11, 2013 | Beta Motorcycles
No fuel to carb
after 3 years sitting the carbs will need a strip/clean/reset...
Oct 26, 2012 | Honda CBR 600 F(3)W Motorcycles
Ryobi 705R weedeater won't run. I can get it to
Yes, it is possible. Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
This should get it running for ya.
Good Luck!
Jim
Jul 24, 2011 | Tools & Hardware - Others
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 19, 2009 | Garden
31cc ryobi weedeater wont start
I've had similar trouble. I removed the plastic cover to expose the fuel lines. I've had to replace all of them as each one had dry rotted, split or had holes. There are four runs of clear plastic fuel line. Check all your lines and then check for any of it being plugged up to the carberator. The primer bulb should develop some pressure when all is good.
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weedeater xt-85t fuel leak
the float in the carb is stuck un screw the nut on the bottom of the carb take it off t6hen put it back on that should do it in the mean time leave that thing out side
May 06, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
