Question about ViewSonic VA721 17" LCD Monitor
Memory recall ok ? this message appear all the time and i can not remove it
  • 11,361 Answers
When it does strange thing like this, you may want to inspect the power supply section.<br /> <a rel='nofollow' href="http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/">http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/</a><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a rel='nofollow' href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Posted on Aug 26, 2010
3 Suggested Answers
Achabacha
  • 113 Answers
SOURCE: "memory recall ok?" message has started appearing on the monitor frequently
Set the "Resolution Notice" to "OFF" in the Setup Menu of your Monitor or alternatively try installing your Monitor Drivers again using the CD which came with your monitor.
Posted on Apr 23, 2009
  • 79 Answers
SOURCE: Memory Recall OK
it may be due to stuck setting button on lcd monitor or due to faulty circuit ... try to see if buttons are stuck ..nudge them a little to see if that makes a difference otherwise call the company technician.
Posted on Aug 08, 2009
How do I reset lamp? I don't have the remote control.
NOTE: If the "Please Replace Lamp" message is displayed, press [RETURN] or [EXIT] on the remote to remove the message.
1. Turn the unit ON.
2. Hold in the [VOL-] button on the front panel and simultaneously hold down the [RECALL] button on the remote control. After 3 seconds, a red "CHK" appears on the screen's left corner. If a solid color screen appears, press the Recall button repeatedly until "CHK" reappears.
3. From within the service mode, hold in the [VOL-] button on the front panel and simultaneously hold down the [MUTE] button on the remote control. Continue to hold (approx. 3 seconds) until the lamp time resets to zeros.
Mar 05, 2015 | Televison & Video
Memory Recall OK
Aug 08, 2009 | ViewSonic VA721 17" LCD Monitor
Apr 21, 2009 | ViewSonic G90fb 19" CRT Monitor
"out of memory" message then printing to screen and printer
You would need to increase your virtual memory and restart your computer. Windows XP:
Right click my computer, go to properties
Select the advanced tab
Click advanced tab
Click change under virtual memory.
Set virtual memory 1500 to 4000
click set and apply, ok
If the memory is set higher, select a higher number.
This should resolve your issue.
Feb 06, 2009 | Microsoft Works 8.0 for PC
MEMORY RECALL OK?
From the Users Manual for this monitor:
"Memory Recall returns the adjustments back to factory settings if the display is operating in a factory Preset Timing Mode listed in the Specifications of this manual. - Exception: This control does not affect changes made with the User Color control, Language Select or Power Lock setting."
When the monitor is asking "Memory Recall OK?" it either wants to initiate a settings Recall, or it's asking if the Recall was successful. In either case, the "Memory Recall OK?" message is supposed to go away when you push either button 1 or button 2.
If it does this when you are adjusting settings then it's likely just doing what you told it to, even if you don't realize you told it to do that.
It's also possible for one of the settings buttons to be stuck down and this is causing it to try and change the Recall settings. Push each of the buttons on the monitor and pay attention to what each one feels like as you push on it. If one of them feels different from the others, it's likely stuck.
Tapping lightly on the settings buttons or on the panel beside them will usually free up a stuck button. If a button is stuck and won't loosen up by tapping beside it, you might need to pry up on the edges of the button VERY gently with the sharp tip of a pointy kitchen knife.
If it's doing this when you did not touch any of the settings buttons at all, then this is likely being caused by a dendrite whisker or faulty circuit trace inside the monitor and you'll need to take the monitor to a service technician for repair. But remember to contact Viewsonic first and go to whatever Service Center that they advise, since a repair of this type may be covered under warranty.
One other thing you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows.
Hope that helps solve your problem...
Feb 09, 2008 | ViewSonic E70f 17" CRT Monitor
MEMORY RECALL OK? problem mine is view sonic monitor .from the past one month its showing problems in display.its giving "MEMORY RECALL OK?" and this whether i press any of the two buttons asked for ,is...
From the Users Manual for this monitor: "Memory Recall returns the adjustments back to factory settings if the display is operating in a factory Preset Timing Mode listed in the Specifications of this manual. - Exception: This control does not affect changes made with the User Color control, Language Select or Power Lock setting." When the monitor is asking "Memory Recall OK?" it either wants to initiate a settings Recall, or it's asking if the Recall was successful. In either case, the "Memory Recall OK?" message is supposed to go away when you push either button 1 or button 2. If it does this when you are adjusting settings then it's likely just doing what you told it to, even if you don't realize you told it to do that. It's also possible for one of the settings buttons to be stuck down and this is causing it to try and change the Recall settings. Push each of the buttons on the monitor and pay attention to what each one feels like as you push on it. If one of them feels different from the others, it's likely stuck. Tapping lightly on the settings buttons or on the panel beside them will usually free up a stuck button. If a button is stuck and won't loosen up by tapping beside it, you might need to pry up on the edges of the button VERY gently with the sharp tip of a pointy kitchen knife. If it's doing this when you did not touch any of the settings buttons at all, then this is likely being caused by a dendrite whisker or faulty circuit trace inside the monitor and you'll need to take the monitor to a service technician for repair. But remember to contact Viewsonic first and go to whatever Service Center that they advise, since a repair of this type may be covered under warranty. One other thing you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows. Hope that helps solve your problem...
Aug 03, 2007 | ViewSonic E70b 17" CRT Monitor
or you have a "crazy" micro or have a stucked push-button (or two) , first I try is change them or at least disconnect it to see what happen.
Jul 11, 2007 | ViewSonic E70b 17" CRT Monitor
Card Error
This is from Konicas site. don't know if this will be any help for you since you had posted a long time ago. you most like have a new camera by now. anyway. Question: When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the monitor display. Answer: Please follow the procedure below. While the message is displayed, press the center of the controller. The monitor display and data panel will turn off. Turn the Main Switch dial to OFF position and remove the CompactFlash from the camera. - When "No Card" message appears next time when the camera is activated in the recording mode, the camera and CompactFlash are OK. - When "Card Error. OK" appears again, the CompactFlash may be faulty. Use other card.
May 05, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Memory recall
Oct 31, 2006 | ViewSonic E70 17" CRT Monitor
Memory recall
Oct 30, 2006 | ViewSonic E70b 17" CRT Monitor
ViewSonic VA721 17" LCD Monitor Logo
88 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
