Question about Mitsubishi Televison & Video
Mitsubishi proyection tv vs-60va2 screen went all blue it has sound but no picture,
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Possible bad picture tube ,
Posted on Aug 26, 2010
Sound is O.K. no picture?
mitsubishi vs4561c projection tv no picture screen is blue sound is ok
Dec 07, 2009 | Mitsubishi VS-45607 45" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Need help repairing Mitsubishi VS 4541 rear projection TV
Visit the site linked here for more details. Repair of many popular brand devices are given. http://electronicshelponline.blogspot.com/
Mar 23, 2017 | Televison & Video
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi 5051
I can help you here follw my pictures and be sure you have a reciever hooked up so the TV can identify it.In some cases like in picture #2 you have to tell the TV that its on by entering it in your self ,(notice the pic.2 Ive selected NO on right side ) you have to use the Volume /Enter keys to make the change,and you probably already learned that you have to highlite each move your at that your changing.d116022.jpg9f9fa1f.jpg
Mar 17, 2008 | Mitsubishi VS-50501 50" Rear Projection...
No picture
If, in a dark room you can't even see the screen lit up, you have probably lost your high voltage driving the picture tubes and if the set is over 10 years old, I'm pretty certain that the parts will be no longer available -- that is one of my pet peeves about Mitsubishi. If you can see a grayish screen, then maybe there's a chance it could be repaired by a competent and dedicated technican.
Jan 13, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Open Questions:
Televison & Video Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
