Question about Haier HWR06XC7 Air Conditioner
Haier hwr06xc7 window unit a/c: fan works, compressor turns on, but just blows room temp air (which sucks when it's 114 deg here). can this model be charged? is there something else i can check first before i go out and spend $$$ on a cheap a/c unit? fuse is not blown, all wired connections seem to be made
  • Haier Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 30, 2010
Fan will not run without starting it yourself and will not run high speed at all
Sounds like an old unit with a bad run capacitor or
check the components on the board for burnt wiring.
Fans on window units are controlled by a 3way switch. High, Med., and low. Your power and in most cases a capacitor which doubles for the compressor and fan.
So it can only be 1 of the 3
Burnt out windings on the motor
Bad switch
Bad capacitor
May 01, 2014 | Haier HWR06XC7 Air Conditioner
WATER COMING THROUG FRONT OF FUJITSU fan coil unit
vent pipes are not sealed properly and condensation is building up and leaking out .
Jun 10, 2017 | Fujitsu 12RLS Halycon Wall Mounted Air...
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
I have 2 Coleman roof ac's on my 34' coach that are ducted. The fans work and the compressors come on but the air isn't cold enough to cool the coach. The front unit temp only goes to 70 deg....
Are there any filters? If they are clogged the unit will not work properly and the temp will not drop as much as it should as it cannot absorb the air in the trailer or room.
Aug 02, 2011 | Coleman Mach 15 Air Conditioner
Temp setting way off kenmore 580
Remove the window unit and dissasemble,and clean it out,careful not to bend the fins on the condense and evaporator,but clean them out,and the inside of the unit also,then see what happens,if the problem persist,then find the probe on the evaporator and move it away from the evaporator until the compressor stays on longer.
May 27, 2010 | Kenmore Single Room Air Conditioner
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
Samsung window unit air conditioner model # AW2402M freezes up one time, and the next time freezes you out of the room. What is wrong with it, Termistat or compressor?
Try to set the thermostat to higher temperature and monitor if the compressor will turn " off " when the room temp. is cool, and turn " on " when the room temp. is high. If does not work then your thermostat is defective. Continue running of compressor with very cold room temp. can build up ice in the unit. The compressora73b784.jpg should shutdown when setting temp. will attain.
Apr 08, 2008 | Heating & Cooling
Not cooling
1. check doors,windows,of room
2.if there is leakage freash air came in.so temparature can not maintend
Jan 30, 2008 | Haier HPAC99ER Air Conditioner
Haier HWR06XC7 Air Conditioner Logo
245 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
