Question about Acer AL1714 17" LCD Monitor
Screen does not work
Hey thanks for stopping by.
the problem i am facing is that the screen is very dim so dark that you cannot be able to see what you are doing. If you look close up you can make out the image being displayed on the screen. would this have to do with anything with the inverter, lamps or backlight? thank you.
  • Anonymous Jul 29, 2008
    tv is on volume is working but the screen is not on
  • erminb Oct 16, 2008
    I bought this monitor yesterday, it worked fine there. When i came home and conected it I bearly saw a picture, it can only be seen on white picture movement.
    Problem Solver:
  • 3 Answers
I have same problem kinda, even if I used a different monitor the same problem happens though.
Posted on Jul 22, 2009
I would suggest to take remote control of the computer - then you can see if it is the screen or the graphics card....www.sumox.com can help you here.
Posted on May 06, 2008
  • 472 Answers
In most cases I would instantly say the inverter has failed. The fact you have an Acer I will say it hasn't failed, it's the electronics doing their job.
The problem you will have is failed capacitors and therefore the protection circuits have sprung into action to protect the remaining electronics in the inverter section.
If you know how to replace faulty/failed capacitors then it's an easy task. If not then I would advise your local TV tech do it for you. Repair wise, the parts are cheap, it's the labour that can get expensive. Going in there knowing the problem though will give you the edge when asking for a quote.
    Genius:
  • 3,422 Answers
HI,
I am not a LCD Tv expert so my advice won't be of use to you.I suggest you to ask the same to Ginko or Benimur.
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Clock light is dim or out?
Sounds like you need a new clock. Parts and repairs cost more than new products.
Apr 11, 2015 | Tivoli Model Three Clock Radio
Why does my screen go dark when I am making a call
It should go dark when you put throne up to your face. That keeps it from getting to warm on your face. If you don't want it to go dark, you can turn the auto dim off in settings under display. It will use more battery, but it shouldn't go dim. Then that may be under another setting.
Aug 26, 2014 | Cell Phones
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
My screen is on the dark side.my battery is okay.i am on ac power.how do i get my screen to lighten up? thank yu
if screen appears to dark, and u can see display in dim,
all u have to do is, change the backlight of lcd screen.
if ur in UAE, contact me3
Sep 24, 2010 | Toshiba Satellite M35X-S163 Notebook
When turned on the screen is dark
Sounds like your contrast is a little too dark. Press the 2nd key and then hold down. This should dim the contrast. If you dim it too much simply daeken it by pressing second and up.
Happy Calculating.
If this helps please dont forget to vote. Thanks
Aug 30, 2010 | Texas Instruments TI-84 Plus Silver...
I have a pyle pld5mu and the screen is dark
Hey honestly what you need to do is send the unit back to pyle and they will repair it. I have the same issue 2 times. What they say is the players power supply went out and that 80% of issues with the pyle products are improper installation. I am selling mine and you should do the same after you get the player back. I hope I could help
Shawn Contreras
Jan 08, 2009 | Jensen VM9510 Car DVD Player
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Dash lights are dim and left side of odometer is dark.
you have one or two bulbs burnt out that can be changed with the dash face removed generally possibly from behind
Dec 08, 2008 | 1992 Lincoln Town Car
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
Acer AL1714 17" LCD Monitor Logo
342 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
