Question about Samsung SyncMaster 753S 17" CRT Monitor
Monitor settings SyncMaster 793s - I cannot get to set the screen bright enough
  • 151 Answers
You can increase brightness by eht .Move button of screen that is placed on eht
Hope this solution works
Posted on Jul 24, 2008
About display settings
try holding all the buttons on the monitor (except the power button) for like 5 seconds. Manufacturers usually put that as a reset feature on monitors. If it doesnt work, consult the user manual.
Dec 04, 2011 | Computers & Internet
SyncMaster 191t Screen is to dark. Brightness is set to 100%.
make sure you have the latest video driver.
Some video drivers you can configure/enhance your desktop settings.. ie. brightness, gamma, contrast..
If you're using windows, right click on your desktop, click Properties, choose the tab Settings, then click on the Advanced button. Choose your video card tab, and continue accordingly.
Jul 17, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
The auto-darken feature(monitor goes dark on dark
In your monitor panel you'll find 4 buttons. Press the menu button and get into Magic Bright. There you can choose the one that best suits you. You can even set to Dynamic contract where the monitor adjusts the brightness according to the elements on the screen
Jun 20, 2009 | Computers & Internet
Brightness automatically going low when the brightness is at 100
hello, please make sure the magicbrite option is not set to "dynamic contrast" as this will change the contrast levels by itself, change the settings by pressing the down arrow touch key on the monitor, change it to any other setting, game mode is blinding on my one (when the monitor works, but thats another story!!!) good luck with samsung customer care centre 0870SAMSUNG (uk)
Apr 04, 2009 | Samsung SyncMaster 2493HM Monitor
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
I want defalt settings of samsung syncmaster 793s 2004 model monitor
The default resulution is 1024 x 768, you can keep the Screen Refresh list at 75 Mhz
If you have been at "Out of Range" then you need to reboot and press F8 before windows load up, then choose VGA Mode. When windows finished loading you can fix the resolution again as you like. Hope this fix your problem
Best Regard!
Dec 03, 2008 | Samsung 793S 17" CRT Monitor
A black flickering line about 5" from the bottom on my samsung syncmaster 793s 17" CRT Monitor
Hi rkarthea,
Well to narrow down the problem I would suggest first that you try to disconnect the monitor from your APC Back-UPS and just plug it directly to the wall outlet, UPS or surge protectors may cause interference at times with some electronic devices. Then if it's still here, I would recommend that you try to degauss the monitor, all CRT monitors have this option in the OSD. You should also check if there is any magnetic device near the monitor, like a speaker or phone that can cause this. If another PC is available can you try it there also, see if the problem is seen on another PC.
Finally, run the monitor self-test, to do this just leave the monitor plugged into the power outlet and disconnet the video cable, and you'll see it. If the problem is still there then most likely the monitor will have to be checked in a service center or be replaced eventually, since this would already be a hardware problem. Especially since you said the problem is apparent even in the OSD.
Hope this helps!
Peace! :)
Oct 23, 2008 | Samsung 793S 17" CRT Monitor
Monitor problem
1240/1024 and 75hz refresh rate
May 09, 2008 | Samsung 793S 17" CRT Monitor
Focus on monitor
Try replacing the filter capacitors on the video circuit.
Apr 28, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
540n screen is bright white
Due to it is new monitor the best way to solve problem is to take monitor back to seller and afterclaim it. Malfunction is inside monitor and you are not able to fix it.
Good luck
Dec 11, 2006 | Samsung SyncMaster 152N 15" LCD Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
223 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
