Question about Lakewood P-25 Box Fan
My Lakewood P25 fan just quit working. I tried pluging it in to another outlet, one thqat i know works, and nothing . no speeds work the motor does not even buzz. the blades turn freely. how can i fix it?
5 Suggested Answers
  • 4 Answers
SOURCE: My Lakewood box fan fell over and stopped working
As the box fan is a simple electronic, I would take the fan apart and check the solder points. If one has broken loose or is cracked, simply re-solder the point. Test it and try again. Another suggestion would be to go to your local hardware store and find some appropriate L-brackets to secure the fan to the sill while still maintaining the ability to remove it and close the window. A little human ingenuity can probably outsmart a cat. ;)
Posted on Jun 27, 2007
bigg t
  • 640 Answers
SOURCE: lakewood floor fan
most likley the set screw that secures the blade to the motor is loose.
Posted on Aug 01, 2007
konzzz
  • 255 Answers
SOURCE: need help with fixing my lakewood floor fan.
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
Posted on May 28, 2009
mcdevito75
  • 1970 Answers
SOURCE: are replacement motors available for these fans?
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Posted on Jul 28, 2010
I have a wall outlet that turns the fan on and I turned it on and the lights are able to work on it but I can't get the blades to move
first, check to see if there is a pull chain or string on the fan motor to control the fan speed. this usually has 4 positions,off,low,medium & high speeds. someone may have turned the speed switch to off.
it done cost nothing but your time to look and you might suceed in turning on the fan motor.
Dec 27, 2012 | Hampton Bay 24002 Ceiling Fan
I HAVE A LAKEWOOD FAN MODEL # HV-14C, and the motor would stop after running the fan for awhile but now the fan does nothing ? now what?
Hi, If you have no sound at all and the fan stopped in mid-use it is probably the thermo protection located under the shrink wrap where the blue power wire comes into connection with the motor field winding. The continuity between the plug end and the blue wire at the Capacitor will be broken. Great care must be taken to prevent breaking the winding wire. The thread-like wire that is painted with varnish or shellac is connected befor the thermo protector, so you don't really have to actually open it up, rather, simply jumper the connection with wire of same gauge and put the new thermo protector inline just befor the capacitor.
Jun 24, 2012 | Lakewood HV-14/C Fan
I have a lakewood fan model hv 21 t that quit working and I would like to know where to get a replacement could you get me a phone number to call I have hard time typing thanks
on the fan motor there should be:
HP
RPM
Voltage
once you have that then the cheapest is eBay:
http://shop.ebay.com/i.html?_nkw=air+conditioner+fan+motor&_frs=1&_trksid=p3286.c0.m359
Bakers will have it:
http://www.bakerdist.com/
Apr 06, 2011 | Heating & Cooling
Fan does not turn on low speed, middle speed. do I need a new motor?
if the motor works, you do not need a new one ! sounds like the switch is bad. if you only get high speed. have a good day !
Feb 12, 2011 | Lakewood HV-12-c Floor / Box Fan
2000 Buick Century. Blower quit working for
I had the same problem. It turned out to be the ignition switch. i have no idea how that is connected to the fan but... it worked, got me my fan speeds back, although it is not working again...
Jul 16, 2010 | 2000 Buick Century
I need a replacement motor, 60 HZ 2.7 amp, for a Lakewood fan Model HV-217SPC
GRAINGER.COM ... .GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
May 28, 2010 | Lakewood MC-42 Fan
My lakewood HV18 just stopped. Spinning the shaft
I think you need to buy a new fan. Unless this thing cost several hundred dollars it isn't worth rewinding and a capacitor isn't likely to cause it to stop working, the cap is for STARTING it spinning anyway and sometimes they are used to HELP it run better, but it will try to run if you spin it and since your's does nothing, more than likely the windings are gone.
Sep 09, 2009 | Lakewood HV 18-c Floor / Box Fan
Need help with fixing my lakewood floor fan.
May 28, 2009 | Lakewood HV 18-c Floor / Box Fan
Lakewood HV-18 fan... how to wire switch?
My switch unit also fell apart as I took the back off and I didn't get to see the correct position of the switch. After much trial and error, I found this to be the initial "Off" position (see photo)
Oct 13, 2007 | Lakewood HV 18-c Floor / Box Fan
Lakewood P-25 Box Fan Logo
85 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
