Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
MY FREEZER ON THE SIDE BY SIDE JUST BEGAN TO DEFROST AND WATER BEGAN COMING OUT ON THE FLOOR COULD IT BE A FILTER NEEDING TO BE CHANGED?
    Problem Solver:
  • 13 Answers
No it is a clooged drain clean it and you should be all set
Posted on Aug 27, 2010
Ice buildup on floor of side by side freezer floor..
Inside the freezer in the lower part of the back wall there's a drain hole wich probably is clough and the water from defrost doesn't go through and freezes up .Put hot water to defrost it and keep pooring it until goes through.If is still clogh try with a wire but do it ery carefull to not put a hole in the drain plstic tube.
Apr 22, 2009 | Kenmore 50522 / 50524 Side by Side...
Ice buildup on freezer floor.auto defrost puts water on floor
You have a clogged drain. If you have a top mounted freezer you might have the drain line on the outside of the fridge. Look for a tube that is thicker than the water intake line and goes from back of bottom of freezer down into the back of the unit to a drain pan. Remove that tube and take it outside and use your hose to shoot a stream of water to clean it out.
If you have a side by side fridge, your drain is still at the lowest point at the rear of your freezer. You may have to removed the rear wall of the freezer to get at it. Remove the back cover to get at the other end of the drain tube. It needs to be cleaned out also.
Apr 22, 2009 | Refrigerators
GSH@%JSTASS - No water, Ice ok, Filter changed, defrosted...still SMART water is not coming
http://www.geappliances.com/search/fast/infobase/10003601.htm
there are only so many comonents to the water suply
ensure there is a clicking sound when you go for water to no the solinoid is actualy actuating. hope this link helps.
Oct 18, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Water leaking from bottom right-rear near valve. Changed inside filter.
you might have a clogged drain in the bottom back of the freezer. When the freezer defrosts the water has no where to go and comes out the front.
Aug 11, 2008 | Frigidaire FRS26R4A Side by Side...
Water collects and freezes in the bottom of the freezer
Your defrost drain is clogged. Get all the ice out and get to the defrost drain hole at the very rear bottom of the freezer. I use a piece of plastic tubing to run down them and clean them out, but you can use a piece of wire if it doesn't have a sharp end that will damage the tube. You can also remove the rear cover of the fridge and you will see the tube going from the cabinet to the drain pan and clean it from there. Post back if you need further help.
Sep 18, 2007 | Jenn-Air JCD2295HES Side by Side...
Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Jul 13, 2007 | KitchenAid Superba Architect KSCS25IN Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
12 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
