Question about Alpine CDA-9885 CD Player
How to set radio After Battery was down - Alpine CDA-9885 CD Player
  • 15,935 Answers
CLICK HERE for the owner's manual
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 26, 2010
I got a Bose wave remote but there's no instruction how to program it to the radio or how to open it for the battery and what kind ot battery it takesn
For programming the radio station settings, hold down a numbered button on the remote for several seconds after you have tuned to the desired station. For setting the time or alarm, use a similar approach, hold the individual button down long enough for the radio to change mode to setting mode. When you are done making a setting, you can wait a few moments and the radio will then return to its regular operating mode. As for the battery, there is a small sliding door on the bottom of the remote that contains a small replaceable disc battery, be sure to get the polarity right.
Feb 13, 2015 | Bose Wave Radio
Radio shuts down
Does it shut down with the AC adaptor pluged in and no batteries?
Jan 10, 2008 | Grundig YB 300PE AM/FM/SW Radio
Radio Resets when I PTT
1) You were right to change to new batteries. Yet, the problem you describe is the same problem that would present itself if you had bad or poorly charged batteries. Check your contacts where the batteries touch inside the radio for damage or film/debris. Clean with a pencil eraser.
2) Is it possibly you have changed a setting, or have your radios programmed to a repeater (duplex only) frequency? Reprogram (if possible) your radios to a very basic setting with the code set to zero (off), and all special features turned off. Then using a basic radio-to-radio frequency test the radios again
3) If reprogramming is not possible due to the radio shutting itself down, then you have a battery or charging problem. Be certain the radio is turned off when on the charger and the battery is clean and inserted the right direction. Try charging both radios overnight. Observe your charger, does it seem like it is operating properly?
Basically, problems are either the radio, the battery, or the charger. By process of elimination you should be able to determine which one is the culprit.
Best regards.
Feb 04, 2014 | Motorola Talkabout T9500XLR - two-way...
I have had my radio for many years but when I wanted to put it in another room it displays a half "L" on the display when I plug it in. Do I have to replace the battery when I'm using an...
Hello
You haven't specified nothing about your Emerson Smartset Clock Radio. Nothing is there about its model number. Yet I posts this solution before you assuming that yours' is a CKS3528 Emerson Clock radio.
There is a long life lithium battery installed in this clock radio when you buy it.
This battery can maintain the time and alarm settings for 3 to 5 years, or even
longer, so there is no need to pay for a new 9-volt battery every 6 months, as
is recommended in other clock radios with normal battery back up.
But if this lithium battery has gone down [ in terms of voltage]; the display 'L" will be there. It means that, it is time to replace this backup battery. It will be of disc type, usually used as bios setting storage, used in computers. OK.
May 13, 2011 | Emerson Smartset Clock Radio
Opening battery compartment on Midland LXT80 2-way radios
First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
Jul 07, 2010 | Midland LXT80 Two Way Radio
Do I need to reset the radio or any other electronics when I change the battery on my 2005 TL?
You normally need any security codes you or the manufacturer have programmed the radio with .
The clock and dashboard configuration will need to be reset
You can make up a set of leads with an open jawed croc clip (so that it fits around the battery posts ) and clip these to the car battery cables while you are doing the transfer
I would suggest that you also wrap the positive lead in a cloth in case you earth it down while you are lifting one battery out and the other in
Sep 28, 2009 | 2005 Acura TL
Motorola EM1000 2 way talkie unable to transmit
Low/Bad battery beep most likely. Try switching batteries to the problem radio and see if the problem goes away. If so, replace the batteries. You might also check the battery contacts both in/on the radio and the battery. Clean with a pencil eraser if necessary.
Jun 28, 2009 | Motorola Walkie Talkie 2-Way Radio
Unable to set the alarm
To Set the alarm time: Press and hold the ALARM button down, and then press the hour/minute buttons to obtain desired time (Note the PM indicator on the screen for PM times)
To Enable the alarm: Move the sliding switch to AUTO or ALARM (Auto is for radio wake and Alarm is for beeping noise) *remember to turn up the volume knob if using AUTO (radio) setting.
Dec 04, 2008 | Lenoxx Electronics Clock Radio With CD...
Set date & time on radio-controlled Timex
Hold down the split/reset button until the flashing tower icon stops flashing then release the button. The watch will automatically receive the next scheduled radio update.
Apr 22, 2008 | Timex 27191 Wristwatch
Alpine CDA-9885 CD Player Logo
24 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
