Question about Whirlpool LER5636P Electric Dryer
I turn it on and it starts to buzz - Whirlpool LER5636P Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
I tried to start the dryer (whirlpool LE5700XK or the LG5701XK, not sure which) and when I hit the start button there was a loud buzzing noise, but no start. I turned the dial to the off position, and then...
Could be a couple things, depending on the buzz you are getting, if it's a buzz from the board like an alarm, it could be a door switch, if it's an electric sounding humming buzz it could be something stuck in your blower wheel like a sock
Jun 24, 2017 | Whirlpool Dryers
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
May 21, 2009 | Hotpoint Dryers
CDI Buzzing
get a screwdriver and cross the start solanoid and see if it turns over and the buzzing might be from a low battery try charging your battery up first
Apr 26, 2009 | Kymco Hipster 125 Motorcycles
Dryer will not start
Hello jslovik,
Welcome
You said, When you turn the knob a buzzing sound starts but that's it. The Buzzing continues as long as the start button is turned. Dryer is only 2 years old. Any help is very appreciated.
It sounds like the starting switch is bad!
10 134398300 Switch,start ,turn type In-Stock $ 11.29It appears in the diagram at the page below in diagram # 10
http://www.pcappliancerepair.com/model-display.php
If you do not know to diagnose this or repair it, please call an authorized tech.
Let me know what you do and how it goes for you?
Huuum
Believed I solved your question.Happy to have been of assistance.
Please remember to leave a rating.
Sep 19, 2008 | Frigidaire FGQ332ES Gas Dryer
Whirlpool lgr4634eqo makes a buzzing noise when trying to start
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
May 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool LER5636P Electric Dryer Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
