Question about Intel Motherboard
Power problems my computer wont turn so and i think the plugs are connected in the wrong plugs that connect into the mother board
  • Tarry101 May 06, 2008
    any help would be appreacicated asap
    President:
  • 2,351 Answers
Hi Tarry101,
Can not help you because you have not listed the model name of the motherboard & the model number. You can find this on the mother board. Depending on the age of the board the model number will be written on the board, usually written in white lettering. (Example), "Asus P4XP-X or AOpend VKM400Am-S".
If you have the manual for the motherboard you can find the model number there.
When you do find the model number click the Ask Me button under my nickname & I'll go over the connections for you.
Mike
Posted on May 06, 2008
My pc desktop wont work its my tower cuz i tried the monitor on a different pc so what could it be
I would think it is either you motherboard or your power supply. I would start by looking at the power supply. You can pick up a tester at any electronics store. Even at that most of the time electronic stores will test the power supply for free. If it isn't that then I would check out the mother board.
Jan 27, 2013 | Acer Aspire Computers & Internet
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
The ATX power supply on my computer went out, so I replaced it with a new one. I connected all the usb and cables in the back, plugged in the power cord and turned on the switch and the mother board powers...
Try refreshing all connections to the motherboard. Also clean the RAM as shown in the image below.cfaa97e.jpg
Resetting the CMOS may also help you in the process. Make sure that the power cable connected to the power supply is disconnected. Change the jumper settings of JCMOS1 (labled 1) from 1-2 to 2-3 for approximately 10secs. (refer to the image below).
Then return to original settings (1-2). Hope this helps.
Oct 06, 2009 | Biostar TForce6100-939 Motherboard
EMachine T2482 Computer won't power on or boot up.
Try removing the power cable from the power supply. Wait 10 seconds, and replace it again. Try powering up the computer. If it doesn't power up, check that the motherboard has power (there should be a LED on the board which is lit up. Of course, check the fuse also in the plug.
If the LED is on, you have a failed motherboard / Switch. If the LED is off, then you have a failed power supply. Beware though, if the PSU has blown, it could easily have taken the motherboard with it.
Mar 14, 2009 | E-Machines T2482 PC Desktop
Compter won't come on
unplug all power connection to your PC then plug it back if problem persist check your power supply and also the power connected to your motherboard unplug the power conector to the mother board and plug it again then turn on you pc.
Jan 08, 2009 | HP Pavillion ZV6000 Notebook
HP DESKTOP COMPUTER
If computer is not powering on then open u r cpu and check the SMPS i.e Switch mode power supply which converts AC to DC it gives a output of 5v & 12v in that the 20 pin or 24 pin connector which is connected to the mother board remove that and short the wires Green and Black and make sure to remove all the power connectors i.e,hard disk,Cdrom or cd writer or DVD writer or any other device and one more connecto which is a four pin connector which is connected to the mother board please remove and test the 20 or 24 pin connector by shorting green and black and behind the smps u have a power cord of ac 220v just plug it and switch on if smps fan rotates that means it's fine then the problem willbe on the mother board just try this
Jul 30, 2008 | Computers & Internet
Power supply
angeldram3
as i think ur processor over heated. or processor can dos not work fine or heat sink not installed properly. remove heat sink, and use heat sink component (a whithe colour gel. u can buy it any computer accessories shop) use it top of ur processor then attached heat sink. and connect processor fan. before installing heat sink check processor fan. then cleare CMOS by removeing battery (because this problem also can happen wrong frequency setting in CMOS setting).
Jun 29, 2008 | Gateway Bestec ATX-300-12EB3 305w Power...
Problem with ASRock P4i45GV
THANHTHHP, memory is very important to start computer.Some cpu's need a minnimum [a pair] 2 memory sticks
Do not plug the power supply ONTO the mother board. Do plug the a/c power cord in back of the power box, turn it on.Does the fan turn on [spin] and u feel air coming out? If fan is on, that is good. If fan is NOT on, that is not too bad because some power supply NEED to connected to the mother board for it to have a path.The power supply can SHOT DOWN if connected wrong or there is a short on or in the mother board. Look to see if ANY piece of metal, one of your screws fell in between metal contacts.,Did u put the computer together yourself? Look to see that the contacts [under the board] are NOT shorting where the screws that hold the mother board down to the chassie body
Apr 25, 2008 | Computers & Internet
Power Problem
Check if you plugged in your monitor cables just right, check it, plug it in, I dont know any other cause of this.
Mar 17, 2007 | E-Machines T1742 PC Desktop
Intel Motherboard Logo
48 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
