Question about Motorola Mobility E815
Speaker so my phone rang today, and it basically sounds like a car speaker when its blown any ideas on ways to fix?
  • Anonymous Dec 17, 2008
    i have a similar problem with my phone. how do i take it apart?
  • 66 Answers
The spreaker needs to be replaced. www.fixphonenow.com can replace the speaker for you for $40.
Posted on Nov 22, 2008
What would cause the driver side front door speaker and the passenger side rear deck speakers not to work. When if fade the sound all the way to the front with no sound in rear and with the balance turned...
Check the speakers if they work. Connect the speaker terminals using a short wire to a 1.5 volt battery (AA or any dry cell batter) and listen if there's a thumping sound when the wires are connected to the battery terminals. If there's no sound, your speakers are busted. If there's a sound, check if the wires are okay. Use the same method with the battery with the wires from the back of your stereo. Make a small cut on the wire and attach the short wires you used earlier.
Nov 04, 2013 | Cars & Trucks
2007 toyota camry audio poor quality
Yes, loose connectiosn, internal integrated amp device burned, bad ground or speakers go to bad.
Aug 22, 2012 | 2007 Toyota Camry
Hi basically picure is there but have no sound!did happen before and by playing around with remote i fixed it but not sure what i done!!any ideas??
your speakers must of blown. i don't know where you can get replacements or if they still make replacements.
Feb 28, 2011 | Televison & Video
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
Very minimal sub-woofer power
The speaker is most likely blown out, and if it is there is no way to fix it, you will just have to replace it
Oct 09, 2009 | Logitech X-530 Computer Speakers
Durango radio fade problems
Your front speakers are more than likely blown. They make all kinds of different models and price ranges to look at. This gives you a good opportunity to upgrade your stock speakers to handle what your throwing at it.
May 10, 2009 | 1998 Dodge Durango
Bose 901 Series IV BLOWN?
Yes, if you hear any sort of crackling sound, that means it has blown. Given the cost of these units, I would suggest repair. I would also suggest contacting Bose, as many of their products have a lifetime warranty, so you might be in luck. Although, blowing your speakers because you made your speakers go louder than they were supposed to, is no covered in the warranty.
You can approach the repair in 2 ways..
1) Send in to Bose for repair - suggested
2) Take it to a service center, and see if they will be able to recone the speakers or replace. Most service centers are familiar with the 901 series, so you should be ok. If they have no idea what your talking about, stay away.
But yes, they are worth fixing.
- OPTiC
DJ & Pro Audio Repair
Jan 17, 2009 | Bose 901 VI Main / Stereo Speaker
I have a kicker 12 xpl that wont play mabey blow how do your determan and can it be fixed I checked the connection the lead directly to speacker and the terminals ?
Here is one quick little way to test the speaker.
Disconnect the wires from the amp that go to the speaker and touch them to a 9 volt battery.
If the speaker moves and you hear a sound then it is NOT blown and if you hear nothing and it does not move then chances are you have a blown woofer.
There are of course other more technical ways to test it with a digital millimeter but the simple 9volt battery quick test is easiest.
If t he voice coil is shorted and blown then there is usually no way to fix that and you would have to replace the speaker. (Some speakers like JL Audio W7 series have removable voice coils that can be replaced but most speakers do not.)
Dec 11, 2008 | Car Audio & Video
Subwoofer has power but not getting sound
Some ideas.
Blown fuse in the amplifier section.
Dead amplifier
Dead speaker.
Amp is not that expensive, call Velodyne
Apr 29, 2008 | Velodyne CHT-10 Subwoofer
Sony XS-V1342A Coaxial Car Speaker
You amp has a low pass filter turned on. There should be a switch to turn it off on the amp, otherwise you need a different amp. Be careful, 600 watts is WAY over the v1342a's rated power of 45 watts rms. If you turn it up too loud, that amp will easily blow your speakers.
Apr 25, 2008 | Sony XS-V1342A Coaxial Car Speaker
Motorola Mobility E815 Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
