Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Our Kenmore diswaher is not clening the dishes anymore what do we need to do
  • Kenmore Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 29, 2010
Kenmore ultrawash diswaher model 665.1374 cycle and options buttons light up but start button does not light and diswaher does not start. please help
Check that the door is closing all the way and that the latch isn't damaged or bent. It sounds like a door switch issue.
Apr 04, 2015 | Kenmore Dishwashers
Bottoms on diswaher do not work
I assume that you mean the spray arms. Check that the arm spins freely when spun by hand, then check the outlet jets at the trailing end of the arm is not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the dishes do not get enough water and chemicals.
May 31, 2011 | Maytag Dishwashers
My kenmore HE diswasher, model number 665.1312 won't dry
is your heating element was working?,if working check the blower if working too.
Jun 04, 2010 | Dishwashers
WATER IN BOTTOM OF DISHWASHER WILL NOT GO DOWN. I LOVE IT THOUGH
Check the diswaher drain at the dish washer wash area down the chamber. clean that filter.
Apr 29, 2010 | Dishwashers
Dishes and glasses are cloudy after competing the cycle. Do you know what I should do? Thanks
yes you need to get a good rinse agent like jet dry you need to use a ggood diswaher gel not powder and you need to buy a bottle of dishwaser cleaner add to an empty dishwasher and turn on closest hot water tap tto make sure water is hot going in to machine do this before you add jet dry to rinse dispenser i follow all instructions on bottle of cleaner it does a good job of cleaning all the **** that accumulates in bottom of dish washer works very good is around 8 bucks a bottle but well worth it
Dec 25, 2009 | Dishwashers
Dishwasher fills but wont start cycle all lights work
check to see if your diswaher float switch is working if you have one in dishwasher there is a relay switch iunder the float if it is not acivating when dishwasher is filled may be defective
Dec 16, 2009 | Kenmore Dishwashers
Kenmore Dishwasher: Our dishes are not getting clean anymore.
This sounds like the sprayer arm isn't rotating freely.
Open the dishwasher and pull the bottom tray forward (remove it if you like)
Reach in and try to rotate the sprayer arm. It should move freely. If you give it a quick flick, it should spin around at least one full revolution before coming to a stop.
Sometimes these become blocked by dishes or plastic bags in the bottom of the dishwasher, other times they simply wear out and you'll need to replace the arm assembly. When I replaced this for our GE dishwasher this spring, the total cost was around $38 for the parts. The replacement took less than 5 minutes, with no tools.
If you want help tracking down replacement part numbers or a source to buy them, comment back here and I'll google them up for you.
And of course, if this helps you, please be sure to hit the thumbs-up button for me!
Dec 14, 2009 | Kenmore Dishwashers
My Kenmore (Mod # 665.17842400) dishwasher stopped towards the end of a rinse cycle (dishes were almost clean). A pool of water is in the bottom now and the controls don't come on anymore. I just...
You may have a small leak in drain hose. check the hose when the unit is draining, you may see the leak.
Let us know if you need further clarification.
Thanks for contacting fixya.com
Dec 03, 2009 | Kenmore Elite 45986 Front Load Washer
Soap door won't open
The rinse aid compartment on my Kenmore Portable dishwasher ( Model 17829) leaks and doesn't hold the solution. It seems to have done this for longer then I can remember. What can be the problem?
Sep 21, 2006 | Kenmore 17252 Free-standing Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
71 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
