Question about De Dietrich DOP390 Pyrolytic Electric Single Oven
Oven will not start, display reads Init - De Dietrich DOP390 Pyrolytic Electric Single Oven
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
We started the oven to bake a pizza, set it to 400 and walked away. A minute later I noticed the oven had turned off, the display, everything. I can not turn it back on, the display is dead.
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Ovens
TEMPERATURE READOUT NEVER REACHES POTENIOMETER DAIL SETTING.ELEMENTS ON OUR DOUBLE STACK 1132 IMPINGER ALL READ CONSISTANTLY 28 AMPS @ 208V.SWAPED THERMOCOUPLES BOTTOM TO TOP TEMP DISPLAY DID IMPROVE BY 50...
You could also check that the fingers are properly fitted in place at the point where thy join oven and the glass window is closed. make sure that all the elements are working well
Jul 30, 2010 | Lincoln Conveyor Oven - 1132-000-A
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
Display reads " -F3-
Replace the oven temperature sensor. Unplug the range. Open the oven. The temp sensor will be in the top right or left of the oven.A short metal piece about half the size of a pencil. Remove the screws,pull it out carefully. Disconnect the wire plug. Reverse this order to install the new sensor.
Sep 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
Getting error F1 on digital display
F1 Board failure Replace control board (also called ERC or clock).
Mar 20, 2009 | Ovens
Error Code (do or) on display
There are two door switches the primary and secondary interlock switch. HEre is the cabinet break down.
Diagram #51 and then Page 7 on this page
Hope this works for you
Feb 14, 2009 | Whirlpool GMC305PD Electric Single Oven
"loc" display
This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
Dec 08, 2007 | Whirlpool Ovens
De Dietrich DOP390 Pyrolytic Electric Single Oven Logo
135 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
Electro Med Services...
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
