Question about Goldstar DH304 Dehumidifier
I would like to SEE a picture of how to hook up a hose from the DH to a drain.( no manual & cant find one for this DH 304) TO lift the bucket off & drain has become to heavy for me. Thanks, Diane deecbud@yahoo.com
My DH 304 is a hand-me-down so I don't have a manual but it did come with a hose attachment which is plastic tube with a threaded end to which you attach a hose. The other end of the tube goes through a hole in the back of the unit and then through a foam screen inside the unit to slip over the drain plug. Aligning the tube and the drain plug can be tricky; it is helpful to remove the bucket to see if you're getting the tube onto the drain plug. Once you have the tube attached to the drain plug, align the tube in the hole in the rear of the unit so that the tab on the tube is inserted into the slot at the hole in the back of the unit.
Posted on Sep 09, 2010
  • 3 Answers
While I don't have your model I believe if you REMOVE the bucket and look UP to the top of the bucket holder you will see a screw on projection to screw the hose onto. Also the hose connection could be on the rear or bottom of the dehumidifier. The bucket will more than likely not go back inside the humidifier with the hose attached....
Posted on Feb 19, 2011
I HAVE AIDYLIS DEHUMIDIFIER#0526011 THAT WHEN HOOKED UP WITH A FLOOR DRAIN STILL LETS WATER GO DOWN INTO THE CATCH BUCKET AND NOT COMPLEATLY OUT THE DRAIN
id ck the drain hose connection for build up of fouling material , the symptom you describe usually occurs when the hose cant drain all the water the machine makes
a wet/dry vac is perfect for this (set to wet) and some even allow you to turn airflow around to blow air as well , this is perfect to clear a stopped up hose (point end into bucket)
Nov 28, 2015 | Dehumidifiers
Direct drain
2 possibilities: #1The port that you plugged the hose onto need to be drilled so the water can come out and enter the hose. #2 The hose cannot be higher at ANY point than the bucket. Physics rules apply and the water will always fill the lowest point. Keep the hose low or raise the dehumidifier up.
Jan 06, 2014 | Danby DDR583R Dehumidifier
Don't see anywhere to hook up hose to the bucket? So that it will continously drain. Model HDN655E-rb
The drain plug should be on the rear of the unit about 1/2 way up the back of the unit. It has a screw off cap and rubber plug. Keep these & don't lose them. You will need them, whenever you stop using the hose drain. Most folks put them in the water bucket for safe keeping.
The garden hose can not exceed 48" in length and slope down and straight to the floor drain. Drainage relies entirely on gravity.
Hope this helps you and thanks for choosing FixYa.
Aug 27, 2011 | Haier HD656E Dehumidifier
Hose hooked up but bucket fills anyway. Hose is attached to internal nozzle. Is that right?
The problem you're having is generally cause by the drain hose or drain hose connection being clogged. When that happens water is diverted to the bucket. To solve this problem do the following:
First disconnect the drain hose for clogs to check for a clog.. Also, the hose should be no longer than 5 feet. If the hose is clear, the clog is in the hose connection or tubing.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor ithe hose for drainage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helps you & thanks for choosing FixYa.
Aug 06, 2011 | Soleus CFM-40 Dehumidifier
How do you hook it up to a floor drain?
With most portable dehumidifiers use a bucket to catch the condensate. Then the bucket is full the dehumidifier stops, then you need to empty it and replace the bucket to get the dehumidifier to start working again.
To make this unit run continually, the bucket can be modified so a garden hose can be attached and the hose can be feed into a floor drain. To do this look at the bottom of the bucket, there should be a hose connector where you can attach a standard garden hose. You will need to drill out the center of the hose connector with a 1/4" drill bit. Then you can attach the hose to the bucket and the other end into the floor drain.
Jul 01, 2010 | Whirlpool AD25BBK Dehumidifier
Our unit is hooked up to a hose drain had has been
proably trash in your diverter (the thing that allows water to run to tank, or hose) try a pipe cleaner or blow with air, is it electronically controlled? or is there a valve?
Apr 03, 2010 | Dehumidifiers
Goldstar dehumidifier
The hose connector does not drain the bucket, it drains the condensate before it enters the bucket. Tube passes through back of dehumidifier by the cord wrap area. (you may have to remove a small cover)
Aug 25, 2008 | Goldstar DH504EL Dehumidifier
Goldstar DH304 Dehumidifier Logo
560 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
