I can not find out from anyone how to clear the reset fault that shyows up on my panasonic PT52LCX15 projection television,''I have already replaced the lamp looking for credible reset instructions'' please help me.
    Genius:
  • 3,422 Answers
There is only one hard reset you can try by unpluging all the cords from back for 4hours and then plug it back.This will restore the factory default settings.
Goodluck,
Please don' forget to rate the solution
Posted on May 06, 2008
Panasonic pt52lcx15 TV. Recently, after approximately 5 min. The TV turns off. Is this some sort of power supply issue? Or, something else?
Try this.
Unplug the tv. take off the back panel. vacuum or blow out the dust with a can of compressed air (@ $3 at Staples). A lot of the projection tvs had a thermal sensor which would turn the tv off if it got to hot.
That is also a good time to clean the lenses. Be careful not to move them out of alignment. My tv worked like new after I did those things.
Jun 10, 2015 | Panasonic Televison & Video
After replacing lamp reset ins. for#PT52LXC15
are you sure you replace the same type of part in the tv..? have you check the dc input/output.?
Thank you
May 06, 2008 | Televison & Video
Pt52lcx15 optical box or lamp problem??
Overheated graphics chip is the probable cause. Get it reseated by a repair centre
Apr 24, 2014 | Panasonic Televison & Video
We just got a panasonic pt52lcx15 tv from a neighbor the tv works fine turns on has sound etc for about five minuets then powers down and the red lamp indicator flashes for about 1 time every 5 seconds
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 20, 2013 | Televison & Video
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
PANASONIC PT52LCX15 REAR PROJECTION BROKEN MIRROR I NEED THE PART
The PN you are looking for is: LSDL0289 I hope this was helpful, best wishes.
May 28, 2010 | Televison & Video
PT52LCX15 sun spot on screen. Is it an easy
Panasonic servicer will have an eprom tool that connects inside the set. It removes spots. After the repair if he calls Panasonic tech line and says he removed fuzzy spots Panasonic will pay for the service. If that does not work then light engine needs replaced.
Nov 24, 2009 | Televison & Video
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
