Question about Compaq CV 7500 17" CRT Monitor
I disturbed settings of compaq 7500 crt monitor, with the front 3 control buttons. How to set back to default settings? Any help is highly appreciated.
    Sergeant:
  • 223 Answers
There should be a default setting in under the menu (on the monitor itself) browse though the menus using the up and down again, look for that defaults option and select it, most monitors have this. hope that helps. use the thumbs if it does.
Posted on Aug 26, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Does my response answer your question? do you need further clarification or help? Please use the solution rating if your problem has been solved, or make a note if your still having trouble. Thanks! Gurvy
I AM GETTING TEARS AND EYE PAIN BEFORE COMPAQ 7450. HOW TO SET ITS BETTER SETTINGS?
Press the menu button and select the brightness,try decreasing the brightness.Also try lowering the constrast and other color.Hope it works.
Oct 20, 2012 | Compaq CV 7500 17" CRT Monitor
Compaq fs740 text too faint and fuzzy to read well
Firstly you need to switch to the monitor's optimal resolution of 1024x768 @ 85Hz and before anyone posts anything about resolution 1024x768 @ 85Hz is the optimum not the maximum. To change to this resolution: Assuming you are using Windows XP click with the right mouse button an an empty part of the desktop and select Properties (or click Start, then click Control Panel then click Display), on the Settings tab, under Screen resolution, drag the slider bar until it says 1024x768 and then click Apply. Also in Display settings you'll find an advanced button, in the advanced panel you'll see the option to adjust the refresh rate, try adjusting this to 85Hz. Now press the Menu Button on the front of the monitor and press + of - until you see an option called "Degauss" and press the select button on the front of the monitor, your screen will do a disturbing jump and flicker accompanied by a metallic thud, this is normal. If this doesn't help message back.
Aug 26, 2007 | Compaq fs740 17" CRT Monitor
I can NOT find the microphone jack on my compaq 7500
Compaq CV 7500 , it does not have either speakers or microphone.
See spec here:
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c00665774&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=313889
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 18, 2011 | Compaq CV 7500 17" CRT Monitor
My compaq 7500 17" colour monitor has five years' dust inside. Compaq company says do not attempt to open the monitor. I have tried to open it but could not as the back cover seems to have too complex...
You can remove the back panel and use an air jet to clean up the PCB and make it clean. The reason why the standard marking is made not to open is to prevent any accident due to carelesnes or inexperiecned handling.
But do not use brush on the components as it might change settings without your kowledge.
Sep 20, 2010 | Compaq 7500 17" CRT Monitor
COMPAQ 7500 monitor, MenuBar/Brightness Bar, Keys not working
replace Menu buttons (Microswitches) and check 5v path
check dry points.
Oct 11, 2008 | Compaq 7500 17" CRT Monitor
Monitor user controls display on the screen
Simply change front pannel microswitches(menu,+,-,select)
Check drypoints
replace 5v reg
Oct 09, 2008 | Compaq 7500 17" CRT Monitor
COMPAQ 7500 SET UP MANUAL
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=219439&prodTypeId=382087&objectID=c00507223
May 19, 2008 | Compaq CV 7500 17" CRT Monitor
Compaq CV 7500 17" CRT Monitor Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
