Question about Garden
I've a Kawsaki ride on mower - engine FJ180V - electric start - turn over won't start, have checked spark - it's ok plus fuel getting to carb bowl ok - air filter clean -any ideas on troubleshhoting welcome - thank you.
  • 755 Answers
Have you tried spraying a little carb cleaner into intake and seeing if it starts?
If it hits on carb cleaner or starting fluid you probably have a blocked main jet.
If you have air, fuel and spark and still no start check compression and timing.
Posted on Aug 26, 2010
Engine will turn over but won't start checked carburator and fuel filter and they are ok are there any saftey switches that would prevent engine from starting?
Since engine is turning over by using the ignition switch it should not be a safety switch problem,
Sounds to me you might have a spark / coil problem
If you have spark then fuel shutoff selonoid on bottom of carb bowl might be bad and not opening.
which in that case I unplug from harness and unscrew from carb bowl , pull out center pin if connected cut off if not throw it in the trash when I do this I always put a shut off valve in the gas line.
You will need a very thin open end wrench to unscrew selonoid from bittom of carb.
Apr 04, 2015 | Ariens 42" 19HP Lawn Tractor
John Deere L110 won't start.
check the solenoid on the bottom of the carb see if there is power if no power check the safety switch on the brake/clutch if there is power remove the solenoid and put power and ground to it to see if it opens if not try and clean it with carb cleaner if that works and opens remove the bowl from the carb and check the needle valve on the float make sure it moves
Sep 01, 2012 | John Deere Garden
John Deere riding mower Model 115 won't start
fuel related if it starts and runs with a squirt
take fuel tank off and clean it out
have to re check the carby
float , needle or float level clogged jet in carby
Apr 28, 2017 | Garden
Turns over but won't start
see if your getting power to the solenoid on the bottom of the carb
Apr 15, 2012 | Garden
My Toro model 20018 won't start. I've changed the plug, air filter and put in fresh gas. Doesn't seem to be getting any spark.
Check if there is spark. Take out the spark plug again and hold against cylinder head with screwdriver. Start motor as usual, see if there is spark on plug when starting. if there is no spark replace ignition module .The next thing is there fuel getting to engine. My guess is that you have a plugged carb. jet. Clean out and reassemble. Be careful not to lose the small parts. Good luck
Jun 10, 2011 | Toro Personal Pace CARB Walk Power Mower
My Craftsman Lawn Tractor 18.5, 42"Mower with Electric Start and Automatic Transmission won't start. (model# 917.275760) won't start. I have put new air filter, fuel filter, battery and spark plug...
Try looking at the screw that holds the bowl in place, sometimes they have a little orifice on them that gets clogged and hinder fuel from reaching carb. Use a small pin or small gauge wire to clean. Good Luck...
Apr 21, 2011 | Garden
Starting engine, Get Click, click, small amout of movement. Changed batt, sole, safe switch, starter, Remove Spark Plugs Engine Turns over Starter spins engine round & round. Plugs back in no good?
Check for spark at the spark plugs. If you have spark, the the problem is fuel related. If your carbs have an electrical solinoid below the bowl, unplug the wire connection and THEN unscrew the solenoid. There maybe a fiber gasket, be careful not to tear it. Unscrew the solenoid and check to see if clean fuel comes out of the bowl. If no fuel comes out, you have to clean the carb bowl and the jet. If clean and FRESH gas does come out of the bowl, then the (fuel shut off) solenoid is stuck in the OFF position. (the alcohol in our gas causes these solenoids to rust and stick) Buy a new solenoid.
NOW if you don't have spark, check the kill switches first, you may have 3 on a riding mower.You can temporaily bypass them if you don't have an ohm meter for testing.
Feb 10, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Engine will start when fuel is poured down carby but then stops. has new fuel pump and is getting spark when turned over.
Remove the carb bowl and see if theres any fuel in the bowl and whether theres water and/or rust mixed with the fuel. If there is no fuel in the bowl then you have a fuel starvation problem. Check to make sure that your fuel line is not kinked so as to restrict fuel flow and then remove the fuel line and place it in a jar and the turn the engine over to see if the fuel pump is pumping the fuel. If you are getting fuel then you will have to disassemble and clean the carb.
Jan 15, 2011 | Garden
Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Jul 23, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower wont start problem is with carb i think. need a manuel
need more info like is the engine spinning over and not cranking, if it spinns over check for spark at the spark plug, if you have spark you now have a fuel problem, if it doesnt spin over at all its probly in the battery or starter. to find out if its a fuel problem just spray carburator cleaner in
too the carburator it dont take much, then try cranking it and see if it runs if it does more then likely the carb needs to be taken off and cleaned, agaian not that hard of a job, just get the carb off and brake it down and spray carb cleaner in every hole in the carb,,,, good luck
Mar 25, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
